No Sound on Philips 3D Smart TV After Connecting Fujitsu Siemens Amilo Pi3540 Laptop via HDMI
Gress11 241212 13
Why does my Fujitsu Siemens Amilo Pi3540 not send sound to a Philips 3D Smart TV over HDMI even though Windows shows audio activity?
The missing HDMI sound is most likely caused by the laptop’s HDMI audio/driver setup, and the Philips TV may only accept PCM or AC3 audio over HDMI [#12312226] Make sure “Show disabled devices” is enabled and set the HDMI/Digital Audio Device as the default playback device, because the graphics card—not the Realtek analog output—handles HDMI audio [#12292215] [#12291415] If the HDMI audio device still does not appear or still gives no sound, try an older NVIDIA graphics driver; one user with the same Amilo 3540 / 9300MGS reported that downgrading the graphics driver restored sound [#12469682] [#12470349] If the TV works with another laptop and the cable is good, the problem is probably not the HDMI cable but the audio format/driver support on this machine [#12312226]
  • #1 12291357
    Gress11
    Rate: 40
    Hello! I think I've already done all the forum topics about my problem. After connecting the Laptop to the TV via HDMI - no sound. In the control panel, I only have Speakers and Realtek Digital Output. When I set the latter to the default after connecting, nothing helps. Still no sound, even though then on the speaker in the windows bar you can see this green sound tip moving. But it doesn't broadcast it to TV. I've already installed other drivers, nothing ...
    My laptop:
    Fujitsu Siemens Amilo Pi3540.
    TV:
    Philips 3D Smart TV
  • #2 12291415
    1 PAWEL
    Help: 674
    Rate: 1364
    Please set Digital Audio Device as default. And check the HDMI cable.
  • #3 12291435
    Gress11
    Rate: 40
    I set up, still nothing, the cable is good, in my friend's laptop the sound works
  • #4 12291618
    1 PAWEL
    Help: 674
    Rate: 1364
    And in the properties, the slider is shifted.
  • #5 12291791
    Gress11
    Rate: 40
    Yes, and when I set it as default, on the Windows bar in this speaker you can see how this audio device detects the sound, because this amplitude increases
  • #6 12292215
    1 PAWEL
    Help: 674
    Rate: 1364
    Show disabled devices.
    The graphics card is responsible for the HDMI output.
  • #7 12292239
    Gress11
    Rate: 40
    I don't have any devices turned off. My graphics card is Nvidia 9300MGS
  • #8 12299030
    Gress11
    Rate: 40
    Anyone have any ideas?
  • #9 12310192
    Gress11
    Rate: 40
    Hello :)
    Moderated By _PREDATOR_:
    Do not post under the post!
  • #10 12312226
    Polon_us
    Help: 1184
    Rate: 1281
    Well, you didn't provide the exact TV model which would be handy :(
    Also, the following considerations are based on data for Philips Smart TV 3D TV 6000 series. I dug through the manual for this TV as well as the support - frequently asked questions. And I invented the following information:
    Audio formats
    o Your TV supports only PCM and AC3 audio format if it is connected by HDMI. If your TV does not receive any sound over an HDMI connection, make sure that your PC is transmitting the audio in PCM or AC3 format. Refer to the user manual of your PC to verify whether your PC is configured correctly.
    It means that a digital signal only in PCM or AC3 format - that is only a stereo signal - can be sent via the HDMI connector to the TV. Which makes sense. Also check what signal format you have set on the audio card.
    From the picture above, you can see that my laptop would not work properly with your TV if we are talking about digitally transmitted audio. I don't have anything connected to the HDMI socket on my laptop, so I don't see an option for this output here. Also check what you have set for the HDMI output. I used the digital output here for illustrative purposes :)
    In conclusion, you will probably need to consider sending the audio signal to your TV analog - via a regular minijack, as long as the digital audio output on your laptop does not support these formats.
    Good luck :)
  • #11 12469682
    pawci01
    Rate: 12
    I had the same problem on xp, it helped to install an older driver for the graphics card (I tested them a bit) installed 7 yesterday and I have a replay of entertainment, in addition the image is worse (when I play a movie in HD) on xp everything was flickering the razor image the sound was like someone will deal with this problem, please answer, Amilo 3540 nvidia 9300mgs
  • #12 12470087
    Gress11
    Rate: 40
    I still have this problem
  • #13 12470349
    pawci01
    Rate: 12
    Test these older graphics drivers
  • #14 15877040
    Lisek CNS
    Rate: 12
    Hello, mom has a problem with the lack of sound on the TV after connecting the HDMI cable, the cable is ok, because it works with the previous laptop where the sound is normal (I also tried other cables). The problem appeared after connecting to a new laptop purchased a few days ago, the system does not detect the HDMI audio device at all, there are only built-in laptop speakers to choose from, I have the "Show disabled devices" and "Show disconnected devices" options selected and nothing is displayed. In the device manager, in the "System Devices" tab, there are two items named "Controller compatible with the High Definition Audio standard", both enabled. Anyone have any idea?
    EDIT: Laptop is Lenovo ideapad 100-15IBD Win 10 Intel HD Graphics, Samsung UE37ES6100 TV
    Edit2: Today, after some major system update, the hdmi output appeared in the sound options, and actually it even set itself to the default. So thanks for the comprehensive and helpful answers to everyone interested in my problem. Greetings.
The discussion revolves around the issue of no sound output from a Philips 3D Smart TV when connected to a Fujitsu Siemens Amilo Pi3540 laptop via HDMI. The user has attempted various troubleshooting steps, including setting the Realtek Digital Output as the default audio device and checking the HDMI cable, which works with another laptop. Suggestions from other users include ensuring that the audio format is set to PCM or AC3, as the TV only supports these formats over HDMI. Additionally, users recommend checking for disabled audio devices and testing older graphics drivers, particularly for the Nvidia 9300MGS graphics card. One user shared a similar experience with a different laptop and resolved the issue after a system update that recognized the HDMI audio output.
