Energy Cabinet Key Access in Terraced Housing Estate: Pre-Meter Fuses, WLZ & Resident Rights
vojtek_o2 64797 27
How can residents obtain the correct key for a locked energy cabinet that contains pre-meter fuses and the WLZ, so they can access their own equipment without calling emergency service every time?
The cabinet most likely uses a standard master-key type lock, so the practical fix is to ask local electricians or the energy distributor for the universal ZK key rather than looking for a unique resident-only key [#12440667][#12440926] One reply notes that these cabinets may use a MASTER KEY lock with insert types K35 or KR32 [#12442660] That same reply says the recipient should have access to meter reading and safe switching through an inspection window or an inspection opening closed with the recipient’s lock, while the sealed parts remain untouched [#12442660] In short, the thread points to a standard energy-cabinet key system plus rightful access to the measurement/control section, not forced emergency callouts for routine actions [#12440926][#12442660]
  • #1 12440626
    vojtek_o2
    We are starting to live in a terraced housing estate and I am writing a bit on behalf of a large number of residents. Power engineers (from the energy distributor) closed lockers in our housing estate. Even before people started living here. Meanwhile, the contents of these cabinets - in part - are our property. We paid for the pre-meter fuses (they are ours), we paid for the WLZ (they are ours), the only thing that was done outside of us was the meters installed and the meters and connections sealed. Everything is locked in cabinets. Each house has its own. Nobody gave us the keys to these lockers and I do not want to give them. For each crap (e.g. a dropped pre-meter fuse, WLZ replacement at a neighbor's place, measurements), an energy emergency must be called and arrived. They agree that we should have the keys (because inside, what is important is sealed and the rest is ours, not theirs), but they will not give us the keys, and their superiors, of course, prefer to charge us PLN 120 for each drive, if it is not a failure. The level of frustration is getting higher. One of the neighbors had already broken the door and picked up the fuse himself. Now he is being threatened with conduct. We tried to look for such keys in electrical wholesalers. So far no result. Can anyone help in getting such a key (photo attached)?
    regards,
    Wojtek
    Please see the announcements in the section and correct the attachment-photo.
    [Akrzy]
    • Energy Cabinet Key Access in Terraced Housing Estate: Pre-Meter Fuses, WLZ & Resident Rights 2.jpg (44.24 KB) You must be logged in to download this attachment.
  • #2 12440648
    highlanderus
    Level 30  
    Help: 174
    Rate: 186
    Have you seen the original key. It is similar to the one from Allegro (offer number-3327964047)
  • #3 12440667
    voytalo
    Help: 61
    Rate: 130
    Every electrician (real, not self-proclaimed) in your area should have such a universal key. I would try this way.
  • #4 12440673
    bobo
    Help: 69
    Rate: 686
    I think my colleague has something to do with this heat. I advise you to look more carefully at the photos posted by vojtek_o2.
    Greetings
  • #5 12440900
    vojtek_o2
    This is not the key from this listing. What the energy workers (from the emergency room) had - has a handle covered with white plastic, in the shape of a diamond. and the tip that goes into the lock is long, in cross section - like a half of a cylinder. and I think he has some teeth. but they open all the cupboards with the same key so this is probably some standard ...
    regards,
    Wojtek
    Added after 4 [minutes]:
    And a note about other electricians. I called two to me. One "borrowed" from a friend who runs a large company and has a full-time job, for a decade, proven, from "more than one furnace ..." etc. He was reorganizing the entire board for me. And he did beautifully. But neither those called by me, nor anyone who has ever repaired anything in this estate (and a lot is happening, because the Mongols that made the installations should have their permissions taken away) - no one has ever seen such a key with their eyes. And they had to get into the boxes more than once.
    greet
    Wojtek
  • #6 12440926
    voytalo
    Help: 61
    Rate: 130
    regards,
    Wojtek
    So that's what I'm writing about. Ask the local electricians if they have a universal key for ZK. Maybe someone will have mercy and lend you some extra money. By the way, each recipient should receive a key from the ZE for their measurement and control part. I don't know why you didn't get ...
  • #7 12441674
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    And they did him very well and they will do the same to anyone who without permission and permission will open what is not his. If someone paid for the fuses, you think that it is your property and you can do what you like. This will quickly straighten your views. This post would be suitable for Moderator.
  • #8 12441722
    voytalo
    Help: 61
    Rate: 130
    You must be exaggerating a bit. Nobody here says that unauthorized people "fumble" at the connector. But an adult can attach an "esa" pre-calculator do not you think? Why call an energy emergency every time for such a simple activity? In my city, they do not even want to come to such cases - you have the key as the recipient and turn it on yourself.
  • #9 12441743
    bobo
    Help: 69
    Rate: 686
    Where did you come from, man? The times of disposing of someone else's property are long over, the actions of ZE in the way presented by a colleague are unlawful extortions of money.
    Greetings
  • #10 12442058
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    The neighbor who pulled out the door was definitely an authorized person, and to break it, the other one definitely broke the seals and now you have the same thing, buddy, you also break the seals in front of the meter and replace the fuses with larger ones (changing the connection conditions).
  • #11 12442086
    voytalo
    Help: 61
    Rate: 130
    Buddy, read the first post with understanding. Who writes about breaking the seals and replacing the fuses with larger ones? It is about the habits of "picking up", closing the tripped circuit breaker. Let's not go crazy.
  • #12 12442118
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    He writes like ... he lifted the fuse. If he had other intentions, he should write attached. I just added about sealing because they are often sealed.
  • #13 12442126
    kkas12
    Help: 1076
    Rate: 4313
    Buddy, it's not the same.
    Here we are dealing with the (intentional) user not being able to restore the power supply after the overcurrent circuit breaker is tripped.
    And you don't have to be an electrician with a valid qualification certificate to turn the switch on.
    This is to charge the user for the team's arrival.
    It is an open protection money for the imposed "care".
    Care not wanted, unnecessary and forced.
    ZE regularly break the law, disregarding the selectivity of security.
    So they do not have the slightest premises, even moral ones, to create their own "legal" requirements.
    All the more so, because it can be seen with the naked eye that the reason for this "solution" is extorting cash from the customer.
    Of course, I do not support breaking locks, but an official inquiry about the legal basis of such a "solution" is perfectly appropriate.
    The times of ZE omnipotence are a thing of the past, which, as you can see, is difficult for some to accept.
  • #14 12442149
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    Yes, buddy, I agree with you 100%, but why the neighbor has a case (probably in court) there is a bottom line in this case. If it were and it should be like the colleague writes, they would get the keys.
    Can't my friend write my nickname correctly ??? [[ kkas12 ]
  • #15 12442155
    tehaceole
    Help: 102
    Rate: 212
    What's this nonsense? Who wrote about the arbitrary exchange of collateral in this thread? We cannot read with understanding?
    ST - SYSTEM
    Maszkowo 24 B, Maszkowo, 75-558 | Company Website: www.stsystem.pl
  • #16 12442188
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    In this forum, my colleague is turning a lot to using the correct terms
    vojtek_o2 wrote:
    he picked up the fuse himself.
    Because then there are such topics and no writing is needed. And what do you think this neighbor has for breaking the lock? Something mate doesn't fit here.
    Ps. Moderator sorry this is the momentum.
  • #17 12442194
    TWK
    Electrician specialist
    Help: 220
    Rate: 510
    Who wrote that they had a case?
    "Threatening proceedings is probably not the same as a case in court.
  • #18 12442223
    zbich70
    Help: 1171
    Rate: 6668
    I do not know what the standards of energy locks are in the capital, but the one in the photo does not suit me in any way. It looks more like a castle built by a manager / community / developer, etc., and energy workers have just such a key.
    If so, then charging a fee in this case is justified - which of you Electricians will start d * psko in the middle of the night to attach S-k to someone for free ???
    Either way, there is a lack of basic information known as the ownership or operating boundary, or the place where energy is supplied. Without it, you can only guess.
  • #19 12442254
    voytalo
    Help: 61
    Rate: 130
    zbich70 wrote:
    who of you electricians will move d * psko in the middle of the night to turn on somebody's S for free ???
    And that's why they should have their key. So much for the topic
  • #20 12442259
    kkas12
    Help: 1076
    Rate: 4313
    I absolutely do not agree with this, Zbyszek.
    I mean charging due to deliberate lack of access.
    The user has the right to take measurements, he has the right to turn off the power, he has the right to turn on the overcurrent switch after it has tripped and has the right to read the meter
    A possible transfer of the operating limit closer to the recipient and beyond the meter is unjustified.
    Can it also seal the residential switchboard and all the miniature circuit breakers located in it?
    After all, their design allows it.
  • #21 12442279
    zbich70
    Help: 1171
    Rate: 6668
    I agree that the deliberate blocking of access by the distribution company and charging for the "services" provided therein call for vengeance to heaven.
    But we still do not know who locked these boxes and who has the keys to them. Officially!
  • #22 12442296
    kkas12
    Help: 1076
    Rate: 4313
    But we know
    For each crap (e.g. a dropped pre-meter fuse, WLZ replacement at the neighbor's place, measurements), you have to call and an energy emergency will arrive . They themselves agree that we should have the keys (because inside, what is important is sealed and the rest is ours, not theirs), but they will not give us the keys, and their superiors, of course prefer to charge us PLN 120 each for each journey if it is not a malfunction.
  • #23 12442341
    zbich70
    Help: 1171
    Rate: 6668
    kkas12 wrote:
    But we know
    We know because this is what the author of the topic wrote. Because it is easier to remember the emergency number 991 than the nine-digit number of the electrician from the "cooperative" who will say after the 15th that ... we know what he will say. ;)
  • #24 12442424
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    We have civil, criminal and fine proceedings.
  • #25 12442619
    stomat
    Help: 257
    Rate: 1982
    And can a colleague justify why he considers the pre-meter protection as his own? In what form did you pay for these collateral? And it is best to quote a point in the contract that begins with "the place where energy is supplied is ...".
    elpapiotr
    Help: 1015
    Rate: 3532
    There may be, for example, a situation (buddy dentist) that the cabinet has (Enion guidelines) a MASTER KEY lock with an insert No. K35 or KR32.
    When one of these inserts is used meter reading by the Recipient it is possible through an inspection window made of a transparent element or an inspection opening closed with the recipient's lock
    Additionally, it enables safe maneuvering of the installation switch through the inspection opening closed with the recipient's lock.
    Beating the foam all the way - is it only normal for me (well, almost normal), and for you (some of you) it is not?
  • #27 12445817
    zbich70
    Help: 1171
    Rate: 6668
    elpapiotr wrote:
    is it only for me it is normal (well, almost normal)
    It is also normal for me - i.e. master keys, recipient's access to read the measurement and switch on the S-ki and no fees in the case of calling an ambulance to "runny nose" ... ;-)
  • #28 12446130
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Ignoring the rules - I'm closing.
Residents of a terraced housing estate are facing issues accessing energy cabinets that contain pre-meter fuses and WLZ, which they believe are their property. The energy distributor has locked these cabinets, requiring residents to call for emergency services for minor issues, leading to frustration. Discussions reveal that local electricians may possess universal keys, but many have not encountered the specific key used by the energy workers. There are concerns about the legality of the energy distributor's actions, with suggestions for residents to inquire about their rights and the legal basis for the locked cabinets. The conversation highlights the need for clarity on ownership and access rights to the electrical installations.
TL;DR: A single emergency call-out costs PLN 120 [Elektroda, vojtek_o2, post #12440626], and “The user has the right to turn on the overcurrent switch” [Elektroda, kkas12, post #12442126] Get your own cabinet key, know the legal hand-over point, and avoid 991 visits.
Why it matters: Immediate access prevents paid outages and potential legal friction.
• Emergency crew fee: PLN 120 per non-fault visit [Elektroda, vojtek_o2, post #12440626] • Common master-key inserts: K35 or KR32 [Elektroda, elpapiotr, post #12442660] • Typical pre-meter fuse rating in Polish homes: 25 A–40 A [IREiESD, 2021] • Listing 3327964047 shows a look-alike key but differs in shank profile [Elektroda, highlanderus, post #12440648] • Inspection window lets residents reset breakers without breaking seals [Elektroda, elpapiotr, post #12442660]
1. Who owns the cabinet and the equipment inside?
The distribution operator owns the enclosure and sealed meter section. Residents usually own the pre-meter fuses (main switch) and the internal WLZ they paid for [Elektroda, vojtek_o2, post #12440626] The contract’s supply point clause confirms ownership split [IREiESD, 2021].
2. Am I entitled to a cabinet key?
Yes. Polish connection rules state the customer must have safe access to devices they operate, including the main switch and reading window [IREiESD, 2021]. Even field staff admitted residents “should have the keys” but management withholds them [Elektroda, vojtek_o2, post #12440626]
3. How much does an unnecessary emergency call cost?
Thread users report PLN 120 per visit [Elektroda, vojtek_o2, post #12440626] URE tariff data shows nationwide call-out fees ranging PLN 100–300 depending on region [URE, 2022].
5. Where can I legally obtain such a key?
Request it in writing from the operator, citing your right to operate customer equipment. Some wholesalers supply K35/KR32 inserts upon proof of address; online listings like 3327964047 sell similar keys but with different shanks [Elektroda, highlanderus, post #12440648]
6. Is resetting a tripped pre-meter fuse legal for a non-electrician?
Yes, if no seals are broken. “You don’t need a qualification certificate to turn the switch on” [Elektroda, kkas12, post #12442126] The Energy Law only forbids tampering with sealed parts, not operating accessible breakers [Prawo Energetyczne, Art. 28].
7. What penalties follow if I break the seal or lock?
Breaking seals can trigger criminal or fine proceedings under Art. 278 of the Penal Code and incur back-billing for unmetered energy. One neighbour faces threatened proceedings after forcing the door [Elektroda, vojtek_o2, post #12440626]
8. How do I formally request a key?
  1. Write to the distributor’s Customer Service, quote contract clause on supply point.
  2. Attach proof of address and ownership.
  3. Demand delivery or supervised duplication within 14 days. Keep a copy; unanswered requests can be escalated to URE [URE, 2022].
9. What is the standard hand-over point (granica eksploatacji)?
For single-family houses, the hand-over point is usually the outgoing terminals of the pre-meter fuse block. Everything downstream belongs to the customer [IREiESD, 2021].
10. How to restore power after the breaker trips?
  1. Open the cabinet with your key.
  2. Verify no damaged wiring; switch off large loads.
  3. Flip the pre-meter breaker to ‘ON’, close cabinet. Total time: ≈1 minute, zero fee [Elektroda, voytalo, post #12441722]
11. What statistic shows the benefit of self-reset?
In estates with 40 houses, one annual trip per house would cost PLN 4,800 in call-out fees (40 × PLN 120) if keys are withheld [Calculations based on Elektroda data].
12. Edge case: what if the lock is a community-installed model?
If the developer fitted non-standard locks, the homeowners association must supply duplicate keys or retrofit approved master-key inserts; otherwise the distributor may legitimately charge for access [Elektroda, zbich70, post #12442223]
