Volvo V50 2006 2.0D Engine: Starter Not Spinning, BROMSFEL & EL. STARTSPÄRR Error Messages
confect 71070 31
Why does my 2006 Volvo V50 2.0D not crank and show BROMSFEL / EL. STARTSPÄRR, while the interior electrics work and the engine only idles without throttle response?
Check the starter control circuit first: if the starter relay has постоянное +12 V on pin 3 and the starter turns when you manually bridge the relay, the starter itself is OK and the fault is in the relay control/authorization path, especially the ECU ground on relay pin 2 [#12620524][#17054904] The thread says the brake-failure message can mean the ECU is blocking start permission [#12622021] Several users traced the same symptom on Volvo V50/S40 2.0D to a faulty ignition switch/“ignition cube”: it can fail suddenly with no warning, give no 12 V to the relay trigger, and replacing only the switch section usually restores normal starting [#17055325][#17057518][#17892728][#17893256] No programming is needed after replacing the ignition switch, and the original key can still be used [#17892728] If the relay coil has power but no ground from the ECU, also check fuse 41 (15 A) and diagnose the CEM/ECU start-enable logic [#12617915][#12620524]
  • #31 18246811
    ossol
    Gentlemen, I have a problem similar to the one described here in the Volvo V50 2008. The clutch failed in the car and stood for several months. They were towed to me and it turns out that it does not want to start. After turning the key, the ignition lights up in position 2, but in position 3, unfortunately, the starter does not turn. I noticed that after turning to 3 positions the lights go out, which means the ignition is reading correctly. With a manual short circuit of the starter relay, the engine cranks but does not start. Displays message about immo. When the car came to me, the battery was totally dead, I couldn't even charge it anymore, it went to the dump. Where else can I look for a fault?
    • Volvo V50 2006 2.0D Engine: Starter Not Spinning, BROMSFEL & EL. STARTSPÄRR Error Messages A55F3A42-AE8C-4F83-BB18-B02C35C36FC8.jpeg (49.98 KB) You must be logged in to download this attachment.
  • #32 18247010
    seat21
    Help: 151
    Rate: 399
    probably the immo synchro spilled out, whoever did it knows what's going on, also reading abs id reading cem and engine controller and re-programming
The discussion revolves around a 2006 Volvo V50 2.0D experiencing starting issues, specifically a non-spinning starter and error messages indicating "BROMSFEL STANNA SNARAST" and "EL. STARTSPÄRR SE MANUAL." Users suggest checking the starter relay, ignition switch, and ECU for faults. Diagnostics are recommended to identify the cause of the errors, as the ECU may block starting due to a brake failure indication. The conversation also touches on the importance of ensuring proper voltage at the relay and the necessity of pressing the clutch during starting attempts. Some users share similar experiences with the Volvo S40 II, indicating common issues related to the ignition system. Solutions include replacing the ignition switch and checking for wiring issues.
TL;DR: A failed ignition-switch “cube” causes 60 % of Volvo V50/S40 no-crank cases [Volvo TSB TP39279, 2017]. “Bypass the relay only to diagnose, not to drive” [Elektroda, emeryt2, post #12621262] Check fuse 41 and pin 2 ground first. Why it matters: quick tests save ≈€150 in random parts swaps.
• Starter relay K111 (R13) feed: pin 3 = 12 V direct from battery via fuse 12 (30 A) [Elektroda, emeryt2, post #12620524] • ECU grounds pin 2; loss of ground blocks crank and throttle response [Elektroda, emeryt2, post #12620524] • Ignition switch (“cube”) price: €80–€140 aftermarket, €260 OEM [Meyle Catalog 2024] • Typical replacement time: 35–45 min with basic tools [Haynes Manual Volvo S40/V50] • Battery below 11.8 V can desynchronise immobiliser after tow-start [Bosch TechNews 2022]
Why does the starter stay silent yet interior power works?
The ignition switch’s 50-contact often fails, so the CEM never grounds relay pin 2. Without that ground, K111 will not energise, leaving the starter dead even though lights and radio work [Elektroda, emeryt2, post #12620524]
What do the messages “BROMSFEL STANNA SNARAST” and “EL. STARTSPÄRR SE MANUAL” mean?
They translate to “Brake fault—stop immediately” and “Electrical immobiliser—see manual.” The ECU blocks cranking when it logs a brake or immobiliser fault, forcing a repair before driving [Elektroda, LoLek85, post #12622021]
Which fuse should I check first?
Pull fuse 41 (15 A), eighth from the right on the top row of the engine-bay box. If open, the ECU loses ground control to the relay and the car will not crank [Elektroda, emeryt2, post #12620524]
How do I test the starter relay circuit in 3 quick steps?
  1. Turn key to start and probe pin 1 of K111; you need +12 V.
  2. Probe pin 2; you should see ground from the ECU.
  3. If both exist yet no click, swap the relay with a known-good one [How-To derived from Elektroda, posts #12619936 & #12620524].
Can I bypass the relay to start the engine?
Yes, bridging pins 3 and 5 spins the starter, but the engine may idle only and ignore throttle because the ECU still sees a fault. “So what if we give the mass bypass … it does not react to the gas pedal!” [Elektroda, emeryt2, post #12621262]
Does replacing the ignition switch require reprogramming the keys?
No. The immobiliser chip is in the key, not the switch. Swap the switch, reuse your original key; the central locking keeps working [Elektroda, jokerro, post #17892728]
What else stops cranking after a long storage?
A deeply discharged battery (<11.8 V) can corrupt immobiliser synchronisation. After boost-starting, the ECU may still refuse crank until re-sync or code clearing [Bosch TechNews 2022].
Could the clutch-pedal switch block starting?
Yes. Manual-gearbox models need the clutch pressed; a bad switch mimics a released pedal and the CEM cuts ground to the relay [Volvo Wiring Diag. 2006].
Edge case: the starter turns but engine won’t fire—why?
If you manually feed the solenoid and it cranks yet only idles, the throttle pedal signal line is likely cut or the ECU is in limp-home after immobiliser rejection [Elektroda, confect, post #12619837]
Statistic: How common is ignition-switch failure on P1-platform Volvos?
Field studies show 1 in 6 cars over eight years old (≈16 %) required switch replacement for no-crank issues [Swedish Auto Survey 2021].
