Removing Balcony Railings: Anchor Extraction Without Damaging Threads or Concrete
kokos28 23313 5
  • #1 12749179
    kokos28
    I have a problem, I wanted to remove the railings from the balcony, but the anchors on both sides make it impossible for me. If I pulled out the anchors on one side, the railing would come out without any problem. I can't unscrew the anchor and I don't want to damage the thread. What should I do?
  • #2 12749192
    Błażej
    Help: 1923
    Rate: 3627
    An anchor, but what? Mechanical? Chemical? Nevertheless, forget that you will pull out without a fight, if at all. Since you have problems with unscrewing.
  • #3 12749217
    kokos28
    mechanical one with a screw
  • #4 12749234
    Błażej
    Help: 1923
    Rate: 3627
    You can only unscrew the nut and drive in the spindle. You will not pull out a tight anchor without hammering it.
  • #5 12749251
    mtracz
    Help: 110
    Rate: 919
    The anchor is designed in such a way that it cannot be removed.
    After unscrewing, if the hole was deep enough, it should be pushed in to hide it.
    So the advice for the future is to drill deeper holes.
  • #6 12749258
    kokos28
    OK thanks. I have an idea, I will stick these pins in on both sides enough to be able to use them again and maybe the railing will come out. And after painting, it will return to its place.
