Honeywell thermostat - thermostat turned off, the heater turns on when the window is open
Marlena Kubat 25683 6
  • Diagnosing one thermostat’s automatic window-open heating behavior
    #1 12960991
    Marlena Kubat
    Above, when I tilt or open the window to ventilate the apartment, the Honeywell thermostat, set to 0, automatically opens the flow of hot water to the radiator. And this is the problem: I`m in the middle of renovation and I need to air the apartment more often. Could any of you give me advice on how to block/switch off this automatic heat flow? I will add that I only have this problem in one room.
    The plumber from the cooperative has already been there five times and claims that nothing can be done, but when I asked why this doesn`t happen in other rooms, he couldn`t answer. Within three weeks, the reading on heat allocators increased by over 100 units.
  • #2 12961195
    Nargo
    Help: 45
    Rate: 206
    You set it to 0 or an asterisk, what is the temperature of the air entering through the window, and whether the head is in a draft.
    look for installers, maybe one of them has a valve cap, so during the renovation you can remove the head and put on the cap and make a regular valve.
    Here is a sample catalog note
  • Thermostatic valve may open despite zero setting
    #3 12961243
    Marlena Kubat
    I set it to 0, the head is under the windowsill, the window is ajar, not wide open. The temperature in the apartment is 20 degrees and above (I wear a T-shirt), the block is insulated, the walls in the apartment are plasterboard. Outside air temperature - as outside in the current weather. I will also add that my apartment is on the top floor, but on the south side, so it is always warm and sunny.
    Thank you for the advice, I will try to buy this valve cap somewhere.
  • Defective thermostat head likely causes heating at zero setting
    #4 12962407
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    If the temperature in the apartment is +20 degrees and when the knob is set to "0", the radiator turns on when the window is open, the head is probably defective. With the "0" setting, the radiator is usually turned off even at a very low room temperature (the * setting means it is turned on when the room temperature drops below 5 or 6 degrees, depending on the brand of the head and is intended to prevent the installation from freezing). Currently, the temperatures are not too low yet, so even if the head was located outside (i.e. outside the room, in the open air), it should close the heating in the "0" position. Yes, you can replace the head with a cap during renovation.
  • #5 12962435
    Marlena Kubat
    Thank you for your answer. Does this mean that I should apply to the cooperative for a head replacement? For now, I covered the head with a small thermal bag, tightly closed and... it works. In any case, this solution does not satisfy me, so starting tomorrow I will start another battle in the cooperative.
  • #6 13586706
    w_pepe
    Rate: 12
    As my friend wrote, try the cooperative, but from what I remember, the valves were leaking and the cooperative repaired it, but nothing happened to the heads.
  • #7 15826450
    Marlena Kubat
    Closing the thread: I wrote a letter to the President of the Cooperative and the heads have already been replaced. Thank you for all your help :-)
The discussion revolves around a Honeywell thermostat issue where the radiator activates when a window is opened, despite the thermostat being set to 0. The user is experiencing this problem in one room during renovations and seeks advice on how to stop the automatic heat flow. Responses suggest checking the thermostat head for defects, as it should not activate at the 0 setting. Recommendations include using a valve cap during renovations and contacting the cooperative for a head replacement. The user successfully resolved the issue by writing to the cooperative, leading to the replacement of the thermostat heads.
