Satel integra WRL, remote upload from TSI-BUILDER to INT-TSI keypad $$$
marcin.daszkiewicz 7656 12
How can I upload a project from TSI-Builder to an INT-TSI keypad over LAN instead of removing the SD card each time?
Set up the keypad and PC on the same network, make sure the keypad responds to ping, enable remote access in the keypad menu before each synchronization attempt, and then in TSI-Builder use the sync tree option to search the LAN for the device [#19096325] [#19096373] [#19096459] The synchronization ports do not matter for project upload, so the ETHM-1 connection port settings are not the key issue here [#19096459] If discovery still fails, temporarily disable antivirus and firewall on the PC while testing [#19096406] Once the network path is working, the keypad should appear under sync after building the project [#19096406] In the thread, using “search LAN” produced a result and solved the connection problem [#19096490]
  • #1 19091183
    marcin.daszkiewicz
    Level 4  
    Hello everyone,
    I am looking for support, the service of someone to help me connect from TSI-Builder to Satel INT-TSI keypads over LAN at home.
    I have an INT-TSI keypad, I create a project in TSI-Builder, but every time I have to remove the SD card and upload this "physically" which is quite annoying, and I know that theoretically it can be done over the network.
    Marcin
  • #2 19092523
    alster1
    CCTV and Stationary Alarms specialist
    Help: 352
    Rate: 540
    Not only theoretically, but above all practically.
    To start with, describe what you have done so far to make this connection work, perhaps you have some thoughts on the subject?
  • #3 19096249
    marcin.daszkiewicz
    Level 4  
    To start with, let a colleague describe what he has done so far to make this connection work, perhaps a colleague has some thoughts on the subject?
    Apparently IP set up, no connectivity. i will be happy to show on priv.
  • #4 19096325
    alster1
    Help: 352
    Rate: 540
    There is nothing to show on the priv.
    Does the TSI keypad have an IP set up on the same network as the TSI-Builder computer?
    If so, is the keypad visible on the network - responding to the ping command?
    Did the colleague enable remote access in the manipulator menu before attempting to connect?
  • TSI Builder connection refused on port 7091
    #5 19096373
    marcin.daszkiewicz
    Level 4  
    Yes.
    If so, is the manipulator visible on the network - responding to the ping command?
    Yes.
    Did the colleague enable remote access in the keypad menu before attempting to connect?
    Yes - in the keypad settings "Remote access - selected enabled"
    Does the TSI keypad have an IP set up on the same network as the computer running TSI-Builder?
    I will add that in TS builder I have in the project properties in the connections tab selected Interface ETHM-1 (not sure if correct), Address: 192.168.100.123, port 7091 (not sure if good anymore), GuardX key: ***************. Connection test: Connection regused: connect.
  • #6 19096406
    alster1
    Help: 352
    Rate: 540
    If this is the case, I would still suggest disabling the antivirus and firewall on your computer for a trial.
    Remote access in the keypad is temporary, you need to turn it on before each synchronisation attempt.
    After building the project, if everything is OK network-wise a name should appear under the sync.
    Satel integra WRL, remote upload from TSI-BUILDER to INT-TSI keypad $$$ .
  • Remote keypad access must be enabled before sync
    #7 19096419
    marcin.daszkiewicz
    Level 4  
    alster1 wrote:
    In that case, I would still suggest disabling the antivirus and firewall on your computer for a trial.
    Remote access in the keypad is temporary, you need to turn it on before any synchronisation attempt.
    switched off, no effect. and the topic of ports? how to check in satel if they are correct?
    alster1
    Help: 352
    Rate: 540
    The ports for project synchronisation should not matter.
    You can still right click on "sync" in the project tree, and "search lan".
  • Search LAN to find the keypad on the network
    #9 19096490
    marcin.daszkiewicz
    Level 4  
    You can still right-click on "sync" in the project tree, and "search lan".
    search over the network, produced a result. mega thank you. I have another question, is there an option to display something on the keypad to change the temperature settings of the wireless temperature sensors ? if so, I will create another topic. I will contact you on priv because I need someone to expand the system, can you?
  • Integra 128-WRL lacks keypad thermostat control
    #10 19096524
    dariusz.bembenek
    Help: 455
    Rate: 615
    No possibility for Integra 128-WRL. Only Integra "Plus" series control panels that have a "Thermostat" type output. On the other hand, another issue is that you can use the keypad and enter the service mode and switch there. However, this is only a dedicated solution for the installer.
    I hope this is not a new installation, because if it is, it is a pity that the Integra 128-WRL was chosen.
  • #11 19096596
    marcin.daszkiewicz
    Level 4  
    The installation is relatively new - about 2 years old. Thanks for your reply. Wouldn't you undertake to service it? Near Lodz?
  • #12 19096613
    alster1
    Help: 352
    Rate: 540
    A bit too far for me, but maybe a colleague has one closer.
  • #13 21344503
    klon2015
    >>19091183 Hey, can you priv? I'm trying to upload a new interface from the card, but something isn't going. Can you help?
The discussion addresses the challenge of remotely uploading projects from TSI-Builder software to Satel INT-TSI keypads over a LAN network, avoiding the need for physical SD card transfers. The user has configured the keypad with an IP address and selected the ETHM-1 interface in TSI-Builder but encounters connection refusal errors. Suggestions include verifying that the keypad and PC are on the same network, enabling remote access on the keypad before each synchronization, disabling antivirus and firewall temporarily, and using the "search LAN" function in TSI-Builder to detect the keypad. It is clarified that port settings typically do not affect project synchronization. Additionally, it is noted that the Integra 128-WRL panel does not support displaying or adjusting wireless temperature sensor settings via the keypad, a feature available only on Integra "Plus" series panels with thermostat outputs. The keypad can enter service mode for installer-specific functions. The installation discussed is about two years old, and there is interest in system expansion and remote assistance.
TL;DR: For Satel INT‑TSI uploads via TSI‑Builder, use a simple 3‑step LAN sync; “Remote access is temporary.” Disable firewall, build, then sync from the Sync pane. [Elektroda, alster1, post #19096406]
Why it matters: It saves time for Satel Integra WRL users who want painless, card‑free interface updates at home.
How do I upload a TSI‑Builder project to an INT‑TSI over LAN?
Use this quick flow:
  1. On the INT‑TSI, enable Remote access in settings.
  2. In TSI‑Builder, Build the project.
  3. In the Sync pane, the keypad name appears; start synchronization. If it stalls, temporarily disable antivirus and firewall, then retry. “Remote access in the keypad is temporary,” so toggle it right before each attempt. [Elektroda, alster1, post #19096406]
TSI‑Builder shows “Connection refused: connect.” What should I check?
Toggle Remote access on the keypad immediately before syncing. Build the project so the keypad name can appear under Sync. Temporarily disable antivirus and firewall to rule out local blocking. Then retry the synchronization. This error often indicates the keypad isn’t accepting the session because Remote access expired or the PC is blocking the connection. [Elektroda, alster1, post #19096406]
Do I need to set a port for INT‑TSI synchronization?
No. “The ports for project synchronisation should not matter.” Use Sync > Search LAN to find the keypad and start synchronization from there. Manual port entries are unnecessary for this workflow. This avoids confusion with other modules and ensures the correct target is selected. [Elektroda, alster1, post #19096459]
Where in TSI‑Builder do I find the keypad for syncing?
Open your project, right‑click Sync in the project tree, and choose Search LAN. If networking is correct, the INT‑TSI will appear by name under Sync after building. Select it and run the synchronization. This discovery avoids manual IP or port configuration mistakes. [Elektroda, alster1, post #19096459]
The keypad pings but sync still fails—what’s missing?
Enable Remote access on the INT‑TSI right before each attempt. It times out between sessions, so a previous enable may have expired. Build the project, then confirm the keypad name appears under Sync. If needed, temporarily disable antivirus and firewall and retry. [Elektroda, alster1, post #19096406]
Can I change wireless temperature sensor settings from INT‑TSI on Integra 128‑WRL?
No. “No possibility for Integra 128‑WRL.” Temperature control from INT‑TSI requires an Integra Plus panel with Thermostat‑type outputs. Without a Plus panel, you cannot expose thermostat controls on the TSI user interface. Consider panel upgrade if thermostat control is a requirement. [Elektroda, dariusz.bembenek, post #19096524]
Is there any installer‑only workaround for temperature control on 128‑WRL?
Yes, but it’s limited. You can enter the keypad’s service mode and switch settings there. This path is intended for installers, not daily end‑user control. For normal thermostat features, an Integra Plus controller is needed. [Elektroda, dariusz.bembenek, post #19096524]
If LAN sync fails, can I still update via microSD?
Yes. Copy the built project to the INT‑TSI’s microSD and update locally. The original poster used this physical method when LAN wasn’t set up. It’s a reliable fallback when Discovery or Remote access isn’t available. Plan to return to LAN sync once networking is resolved. [Elektroda, marcin.daszkiewicz, post #19091183]
Do I need to share my config privately to get help?
No. “There is nothing to show on the priv.” Start with basics: same LAN, ping replies, and Remote access enabled. Those checks usually surface the cause. Only share sensitive data with trusted installers if required. [Elektroda, alster1, post #19096325]
Does Remote access stay enabled indefinitely on the INT‑TSI?
No. “Remote access in the keypad is temporary.” Turn it on immediately before syncing each time. If you wait, it expires and the connection is refused. Keep the TSI‑Builder window ready so you can sync right after enabling. [Elektroda, alster1, post #19096406]
Did LAN discovery actually fix this issue for someone?
Yes. In this thread, 1 out of 1 reported cases connected after using Search LAN. The user confirmed discovery found the keypad and synchronization proceeded. This validates the discovery approach when manual settings fail. [Elektroda, marcin.daszkiewicz, post #19096490]
I’m far from installers—can I still get help expanding my system?
Remote help may be limited by distance and access. One installer declined due to being too far and suggested finding someone closer. Look for a nearby certified Satel installer for on‑site work. [Elektroda, alster1, post #19096613]
I selected ETHM‑1 in project properties—could that block INT‑TSI syncing?
Use the Sync workflow instead. Right‑click Sync and run Search LAN to target the INT‑TSI directly. Project synchronization does not depend on manual port settings or ETHM‑1 selection for the keypad. This approach avoids misconfiguration. [Elektroda, alster1, post #19096459]
