Power Adapter Screeching Noise: Impact of Apartment Power Outages & Potential Reasons
Marcin1946 23505 12
Why is my power adapter making a screeching noise again, and could the apartment power outages yesterday be the cause?
Probably not; the screeching points more to the PSU/voltage converter itself, so check the primary-side parts, especially the large electrolytic capacitor for bulging or leakage [#13498584] The noise may appear when power demand rises, for example during gaming, and the same PSU problem can go together with blue screens, resets, or a momentary black screen [#13498628] It is also possible that the unit is simply too weak for this system and starts squeaking under load [#13498638] If the computer and PSU are still under warranty, send it in immediately while it still works [#13498678]
  • #1 13498572
    Marcin1946
    Hello, I once wrote about the strange sound of the power supply (screeching), for the last whole month it was fine, the power supply worked normally, it did not make any strange noises until today. Could this be the reason that traffic jams went twice yesterday in the apartment?
  • #2 13498584
    Andrzej Ch.
    Help: 223
    Rate: 393
    This is the squeaks of the voltage converter. First, check the elements on the primary side of the power supply, and in particular if the "large" electrolytic capacitor is not bulged.
  • #3 13498599
    Marcin1946
    Generally started making a noise during the game now it's ok again
    In general, he has a blue screen more than once and a reset, or the screen disappears for a moment, I do not know what the problem is.
  • #4 13498601
    DVDM14
    Help: 315
    Rate: 553
    What brand is this power supply? It is printed on its housing.
  • #5 13498603
    Marcin1946
    Corsair VS 450 ATX
    My computer parameters:
    Motherboard: Gigabyte GA-B85M-D3H
    Intel Core I5-4570 3.2GHz processor
    MSI GeForce GTX 660, 2GB DDR5 (192 Bit) OC graphics card
    Corsair VS 450W ATX power supply
    Team Group Vulcan Gold Memory - DDR3-1600 CL9 - 8 GB (2x4GB)
    Western Digital Caviar Blue, 3.5 '', 1TB
  • #6 13498628
    Andrzej Ch.
    Help: 223
    Rate: 393
    Well, you have the answer, the power demand increases during the game, which means you have bluescreens or windows overhangs and the power supply starts squeaking - for starters - as I wrote, check the elements on the original side of the power supply
  • #7 13498634
    Marcin1946
    Primary side components?
    But for the last month, even with the games, everything was fine.
  • #8 13498638
    Andrzej Ch.
    Help: 223
    Rate: 393
    Most likely, there will be an electrolytic capacitor to be replaced - it could bulge and the electrolyte could leak out. And the power supply did not get hot during the game?
    Temperature will kill anything. It seems to me that you have a little too small (in terms of power) this power supply for such a set.
  • #9 13498643
    Marcin1946
    It doesn't get hot, where is this electrolytic capacitor?
    Can you have a photo of what it looks like?
  • #10 13498652
    Andrzej Ch.
    Help: 223
    Rate: 393
    I do not have such a power supply, so I will not take a photo. But you probably know what an electrolytic capacitor looks like. There should be 1 or 2 capacitors (large dimensions) with a voltage above 350V.
    I found such a photo of the inside of the power supply:
    I mean that blue element on the top left.
  • #11 13498659
    Marcin1946
    And this is in the power supply, without opening it, I will not find out if it really is, and for the warranty to the online store I would have to send the entire computer back because they were assembling me. Where then can there be blue screens and a reset or screen disappearance for 2s.
    Added after 4 [minutes]:
    But you don't know for sure it was done with me?
  • #12 13498678
    Andrzej Ch.
    Help: 223
    Rate: 393
    If you have problems with your computer, as you write, and the equipment is still under warranty, you should take it immediately while it is still working. Complaints about power supplies can be a strange thing, because they can prove to you that the power supply has died due to overvoltage in the power grid and there may be a problem with the warranty. Better take the computer while it's still working.
  • #13 13498683
    Marcin1946
    Ok, then I have to send back the warranty because it was submitted to morele.net
The discussion revolves around a user experiencing a screeching noise from their Corsair VS 450 ATX power supply, which coincided with power outages in their apartment. Responses suggest that the noise may be due to the voltage converter or issues with primary side components, particularly the electrolytic capacitor, which could be bulging or leaking. The user reports additional problems such as blue screens and temporary screen blackouts during gaming, raising concerns about the power supply's capacity for their hardware setup. Recommendations include checking the power supply components and considering warranty service due to potential overvoltage issues.
