No Picture on NC+ PVR BOX+ Decoder: Solutions for HDMI Image Loss on Toshiba 40L6353DG TV
Rakietowykoks 71730 11
How can I restore the missing picture over HDMI on my NC+ PVR BOX+ decoder while sound and the on-screen menu still work?
Resetting the decoder and, if needed, the TV to factory settings fixed the HDMI picture loss in this case. If the HDMI connection still shows the menu and channel info but no broadcast image, the HD button may do nothing, so the problem is not just the picture format setting [#13531800][#13532214][#13532353] Another suggested fix was to disconnect the Pace PVR from power, hold the power switch while plugging it back in, keep holding until the LED changes color, then release and wait for it to boot [#13531953][#13532622] After the reset, the user reported that everything worked again [#13534908]
  • #1 13531666
    Rakietowykoks
    Rate: 28
    Hello. I have a strange problem with my set-top box and exactly yesterday I still had everything OK, the image and sound was OK via the HDMI cable, today I turn on the TV and suddenly there is no picture, but the sound and frames as you switch channels, there is also no image in the materials recorded on the disk. I changed HDMI to SCAR and the image is back but there are black bars on the sides. My set-top box is PVR BOX + and the toshiba 40l6353dg TV.
  • #2 13531800
    grubs
    Level 32  
    Help: 171
    Rate: 312
    Have you tried changing the image format with the HD button?
    Does the OSD menu appear?
  • #3 13531831
  • #4 13531923
    Rakietowykoks
    Rate: 28
    grubs I'm set to 1080p and 16/9 so I didn't change anything the whole time.
    mihal2002 but how is it possible that it switches itself so that there is no picture but there is sound?
  • #5 13531953
  • #7 13532106
    grubs
    Level 32  
    Help: 171
    Rate: 312
    You did not answer whether the menu appears when connected via HDMI.
  • #8 13532214
    Rakietowykoks
    Rate: 28
    grubs sorry i didn't notice. Everything except the picture of the broadcasting channel appears. So I can see information about the channel and can enter the menu normally.
  • #9 13532238
    grubs
    Level 32  
    Help: 171
    Rate: 312
    And when changing the image format with the HD button, what happens?
  • #10 13532353
    Rakietowykoks
    Rate: 28
    Nothing happens.
  • #11 13532622
  • #12 13534908
    Rakietowykoks
    Rate: 28
    Okay, everything works, I reset my set-top box and TV to the factory settings. Thanks for wanting to help. You can close.
The discussion revolves around a user experiencing a loss of picture on their NC+ PVR BOX+ decoder connected to a Toshiba 40L6353DG TV via HDMI, while sound remains functional. Various troubleshooting steps are suggested, including checking the image format settings, consulting the decoder's instructions, and verifying if the on-screen display (OSD) menu appears. It is noted that the issue may stem from a change in system settings by the operator. Ultimately, the user resolves the problem by resetting both the set-top box and the TV to factory settings, restoring functionality.
