Creative EP-830 Headphones: Right Earpiece Volume Decrease - Possible Burnt Converter?
delform_17 46338 2
  • #1 13760321
    delform_17
    I am writing as recommended now.
    Over a year ago I bought the creative EP-830 headphones, but after a while the right earphone started to sound quieter. I replaced the jack plug, but to no avail. So I do not know whether it is possible to open the handset itself, whether it is glued somehow or you have any other advice. ew is it possible that the converter in the right earpiece could have burned out?
  • #2 13761575
  • #3 13761828
    gradek83
    Help: 929
    Rate: 2099
    Clean the mesh cover with isopropanol or some alcohol, the earwax has probably clogged the fine gaps in the mesh. If you have a multimeter, you can also check the resistance of the sound converters should be more or less the same.
