Setting Permanent IP for Bizhub c203 Printer Connected to TpLink TD-W8951ND Router
RhumZeiss 19617 9
How can I keep a Bizhub c203 printer on a permanent IP address when my TP-Link TD-W8951ND router does not support DHCP reservation?
Set a static IP address directly in the Bizhub c203 printer and do not rely on DHCP reservation in the router [#14230880][#14234177] Access the printer’s admin page through its current IP; one reply notes the admin password may be `12345678` [#14230909] In the printer’s network settings, enter the IP address and subnet mask manually, which is effectively the same as disabling the DHCP client [#14233797][#14234177] Choose an address outside the router’s DHCP range so it will not be reassigned by the router [#14230880]
  • #1 14230856
    RhumZeiss
    What do i need
    On Amen, bind the MAC address of the printer to the IP address.
    Equipment:
    I have a printer Bizhub c203 connected to the router TpLink TD-W8951ND I connected computers to it through a switch.
    Problem:
    After each power failure or turning off the devices, the printer receives a new address from the pool. When I enter the router settings, it turns out that there is no possibility of linking addresses there. For this reason, I have to change the addresses in the printer driver settings on each computer every day.
    Previously:
    Previously, I had an almost identical configuration, with the difference that the router was better (instead of the TD-W8951ND there was TpLink TL-MR3220 ). It supposedly had the ability to bind MAC and IP addresses, but that didn't work! So the problem was the same.
    What should I do?
  • #2 14230877
    voyytas
    Help: 8
    Rate: 30
    And is it not possible to hard assign an IP address to the printer? (I mean in the printer settings) Even if the router has DHCP set up, the printer will still have the same address, provided it is in the DHCP address pool set on the router.
  • #3 14230880
    m.jastrzebski
    Help: 679
    Rate: 865
    RhumZeiss wrote:
    What do i need
    Equipment:
    Problem:
    After each power failure or turning off the devices, the printer receives a new address from the pool. When I enter the router settings, it turns out that there is no possibility of linking addresses there. For this reason, I have to change the addresses in the printer driver settings every day on each of the computers.
    Previously:
    What should I do?
    Enter the network settings through the printer's configuration panel, disable its DHCP and give it a static address, but outside the DHCP range assigned by the router.
    jprzedworski
    Help: 758
    Rate: 828
    As above - use the browser to access the current printer address. The admin password, if I remember it, could be 12345678.
    http://open-sez.me/passwd-konicaminolta.htm
  • #5 14230928
    mbo
    Help: 2333
    Rate: 845
    The second option is to assign a specific IP address based on MAC in the router's DHCP settings.
  • #6 14230937
    m.jastrzebski
    Help: 679
    Rate: 865
    Read the first post carefully - his router doesn't have this functionality.
  • #7 14233797
    RhumZeiss
    Indeed, the password 12345678 has discovered a printer area unknown to me. I can't see DHCP being turned off there, but there are manual IP and mask settings! I'll bury it and let you know what I found there.
    mbo
    Help: 2333
    Rate: 845
    Setting IP manually is the same as disabling the DHCP client.
  • #9 14235304
    rwisniewski1
    Help: 40
    Rate: 39
    Please read the user manual carefully:
    Link page 35.
  • #10 14517013
    RhumZeiss
    Thank you very much. it helped.
The discussion revolves around setting a permanent IP address for a Bizhub c203 printer connected to a TpLink TD-W8951ND router. The user faces issues with the printer receiving a new IP address after power failures, necessitating daily changes in printer driver settings on connected computers. Suggestions include disabling DHCP on the printer and manually assigning a static IP address outside the router's DHCP range. Users also mention accessing the printer's configuration panel via a web browser and refer to the user manual for detailed instructions. The router's limitations regarding MAC to IP binding are acknowledged, as it lacks this functionality.
