[Solved] Peugeot Partner 1.6 HDI EGR Error Codes P0490 & P0401: Symptoms, Diagnosis, and Replacement Guide
fhukonrad 88770 12
Why do Peugeot Partner 1.6 HDI EGR faults P0490 and P0401 keep coming back after replacing the EGR system, and what should be checked next?
On a DV6, repeated P0490/P0401 after replacing the EGR parts usually points to the valve electronics/position sensor, the wiring/connector, or the airflow meter rather than the need for cleaning or adaptation [#14712773][#14712836] One reply says no EGR adaptation is needed on DV6, and if the fault remains the valve may not fully open/close or the electronics may not trust the position signal [#14712773][#14712836] Another practical check is to inspect the contacts in the MAF and EGR plugs, bend them back if needed, then log live data and compare requested vs actual airflow/EGR values while driving; in that case, replacing the flow meter fixed all EGR errors [#20257387] A later reply also mentions an EEPROM/ECU data crash as a possible cause, with the problem disappearing after loading a new batch [#14716788]
  • #1 14327092
    fhukonrad
    Rate: 79
    Hello everyone. After reading various posts, I did not find a similar one, so I assume another one related to HDI and EGR. Well, I got a Peugeot with the typical symptoms of a damaged EGR. After PP diagnosis, two continuous errors P0490 EGR insufficient performance, valve closed too close to reference value, and P0401- Measured air quantity higher than set value. After verification, everything is nice. They were substituted from another Partner set. EGR, i.e. EGR valve + loading, cooler and pipe connecting the cooler with the manifold, throttle and flow. The catalyst was also unfastened. Unfortunately, after firing, it works once, once it does not work in the parameters. One time it is 212 and another time 420. Also while driving, you can go 10 km and you can 100m and it closes, causing errors as above. I decided to substitute the engine controller and still unchanged. While driving, the set EGR parameters reach up to 850 and the measured one reaches up to 1000. The turbine pushes 2050 mbar and here the set parameters are practically identical with the real ones. Also book fuel parameters. Where else to look for the cause of this EGR?
  • #2 14334392
    fhukonrad
    Rate: 79
    Nobody has an idea? Priority topic ...
  • #3 14712710
    mariusz_sl
    Rate: 31
    After replacing the EGR, the adaptation data must be deleted and the EGR must be re-adapted. Necessarily on a warm engine at least 70 ° C. The computer will carry out the adaptation by itself when stationary or while driving, providing guidance to the driver. The problem disappeared after such fun in 407 2.0.
    I have a question: How to remove and clean the EGR in the Peugeot 308 SW. According to for me it is on the back of the engine and there is no access there.
    Help.
  • #4 14712773
  • #5 14712790
    mariusz_sl
    Rate: 31
    Thanks for the information. A friend has a plus.
    I have one more question.
    Can the error regarding the adaptation of the EGR valve be caused by the use of the car on short distances - 10 km to work and back home once or twice a month, about 100 km?
    I will be very grateful for the tips because I can see that we have an expert.
  • #6 14712836
  • #7 14716367
    mariusz_sl
    Rate: 31
    fhukonrad wrote:
    Hello everyone. After reading various posts, I did not find a similar one, so I assume another one related to HDI and EGR. Well, I got a Peugeot with the typical symptoms of a damaged EGR. After PP diagnosis, two continuous errors P0490 EGR insufficient performance, valve closed too close to reference value, and P0401- Measured air quantity higher than set value. After verification, everything is nice. They were substituted from another Partner set. EGR, i.e. EGR valve + loading, cooler and pipe connecting the cooler with the manifold, throttle and flow. The catalyst was also unfastened. Unfortunately, once it is launched, it works once, it does not work in the parameters. One time it is 212 and another time 420. Also while driving, you can go 10 km and you can 100m and it closes, causing errors as above. I decided to substitute the engine controller and still unchanged. While driving, the set EGR parameters reach up to 850 and the measured one reaches up to 1000. The turbine pushes 2050 mbar and here the set parameters are practically the same. Also book fuel parameters. Where else to look for the cause of this EGR?
    Often there are problems with the previously working or new part. Maybe the EGR that you replaced just like the previous one is stuck?
    Added after 5 [minutes]:
    georgesgr wrote:
    You'll shut down this great engine with this kind of service. Indeed, the valve could be messed up in this case. "Adaptation" is made when the ignition is turned on. If there is an error, the valve probably does not close or does not open fully or the electronics believe it (damage to the position sensor, for example). Therefore, I repeat: in my experience, cleaning has never done anything.
    This situation has been bothering me for some time. The wife and children travel by car to school and work 10 km one way. It is true that I change the oil often (10,000) along with the filters. However, from Monday they will be swapped for cars :) . I will watch the EGR and from Monday it will be heated over a distance of 60 km every day and 180 km once. Comments and tips are welcome.
    Regards
  • #8 14716788
    fhukonrad
    Rate: 79
    I have an EEPROM crash, and why I don't know. I have uploaded the new batch and everything works as needed.
  • #9 14738899
    mariusz_sl
    Rate: 31
    Well, apparently recently, it often happens that electronics for an unknown reason break down or generate IT errors. Maybe because the Chinese have already specialized in everything and even BOSCH sticks only its stamps on their products.
  • #10 20257387
    Zen1973
    I would start by bending the contacts in the plug of the flow meter and EGR. Then you have to drive with the computer and check the values of the flowmeter (the data from it control the opening of the EGR), whether the set and actual values coincide. For me, only the replacement of the flow meter eliminated all EGR errors
  • Turbo unlikely; P0403 and P0406 point to EGR circuit faults
    #11 21078980
    joannatokarska76
    >>14716788 Hello, I know it's been a few years but I have a question with what you uploaded the eeprom, I don't know what to do. I bought the car but found out I was cheated. The car had the dpf cut out, ran fine for a month, now the egr error p0403 has popped up. I found the mechanic who did it and he says it's the turbo compressor. The turbo has been taken out and everything is working fine. The car has no power and smokes black. And the obd only shows two errors P0403, P0406, could it be the turbo?
  • #12 21389687
    fhukonrad
    Rate: 79
    Recently with another HDi a similar problem. Again, the batch is out. I have already mastered the EGR topic on the HDi to perfection. Faults in HDI are easy to deal with, so there is no need to be discouraged by these engines. The important thing is that all parameters are within normal limits and it will return the favor with longevity. Topic to be closed.
  • #13 21390112
    fhukonrad
    Rate: 79
    Described in previous post.
✨ The discussion addresses persistent EGR-related error codes P0490 (EGR insufficient performance) and P0401 (measured air quantity higher than set value) in a Peugeot Partner 1.6 HDI. Despite replacing the entire EGR system—including valve, cooler, connecting pipes, throttle, and catalyst—and even the engine controller, the errors and erratic EGR behavior persist. Key insights include the necessity of EGR adaptation/reset after replacement, ideally performed on a warm engine (≥70°C), although some users report no adaptation needed on DV6 engines. Cleaning the EGR valve is generally ineffective; electronic faults, such as position sensor damage or stuck valves, are more common causes. Short-distance driving may contribute to EGR malfunction due to insufficient heating. Faulty or stuck replacement parts and electronic control unit (ECU) EEPROM corruption can also cause recurring errors. Additional advice suggests checking and bending contacts in the flow meter plug, as flow meter data controls EGR operation; replacing the flow meter has resolved EGR errors in some cases. The discussion also notes potential quality issues with aftermarket electronics. Overall, ensuring correct adaptation, verifying sensor and flow meter integrity, and considering ECU firmware stability are critical for resolving EGR faults in Peugeot HDI engines.
