TL;DR: EL84 output tubes can run at 220–240 °C, and “working time at this temperature is unlimited” [Elektroda, fzyga43, #14606349; Elektrola, aksakal, #14606691]. Focus on plate current ≤ 12 W, swap only bad electrolytics, and an ECC85 often revives FM.
Why it matters: Correct triage prevents needless parts swaps and protects rare vintage components.
• EL84 max anode dissipation: 12 W at 250 V [Philips Datasheet].
• Loewe Opta Apollo VHF range: 87–100 MHz [Elektroda, aksakal, post #14608318]
• Filter electrolytics: Typ. 2×50 µF/350 V, reform time 2–4 h daily for 3–5 days [Elektroda, aksakal, post #14606855]
• New ECC85 tube price: ≈ 8–15 PLN [Elektroda, dostojny.kocur, post #14609032]
• Safe chassis surface temp: < 50 °C to avoid user burns [IEC 60065].
1. Why do the EL84 tubes feel dangerously hot?
Power pentodes dissipate up to 12 W each, heating the glass to 220–240 °C, which is within spec
[Elektroda, fzyga43, post #14606349] Touching them causes instant pain, but the tubes are operating normally.
2. How can I check if my EL84s run within safe limits without a tube tester?
Measure voltage at pin 3 (anode) and pin 7 (cathode). Calculate current: I = V/Rk. Ensure Pa = Va × I ≤ 12 W [Philips Datasheet]. A basic multimeter suffices
[Elektroda, aksakal, post #14606691]
3. One EL84 glows brighter—is that a fault?
4. Should I replace all capacitors in this radio?
5. Which capacitors are critical to change first?
Priority parts: 1) Filter electrolytics that cause hum; 2) Paper coupling caps feeding EL84 grids—leakage here can push plate current above 70 mA, risking transformer failure
[Elektroda, piotrekjjj, post #14607682]
6. What is capacitor reforming and how do I do it?
7. How much will new parts cost?
Approximate Polish prices: ECC85 ≈ 8–15 PLN
[Elektroda, 14609032]; two 50 µF electrolytics ≈ 10 PLN each (TME list); premium EL84 pair ≈ 120 PLN. Labour varies; hobbyists budget 50–100 PLN total.
8. Why does the set hum with volume at zero?
9. How can I improve FM reception?
10. Which antenna socket is which?
11. Can I substitute an ECC81 for an ECC85?
12. Do new tubes require bias adjustment in the Apollo?
No manual bias. The set uses cathode resistors that self-bias; simply insert matched tubes [Service Manual].
