Gentlemen, the management of the community intends to install a weathervane in a block of flats.The block was built using a traditional method in the 1950s.The block is uninsulated,plastered and consists of three staircases.The building is three-storey,with 12 flats in each staircase.Four flats are 38 m each and 8 are 50 m each.In all the flats there is an old central heating system with cast-iron radiators and old spindle valves.The valves cannot be closed, I am afraid to move them.The radiators have not been flushed for decades.The heat supplier is MPGKiM which has a new generation boiler house for woodchips and has a weathervane in the AKPiA.Gentlemen, what can be the cost of replacing all the valves and adapting them to control by means of the weathervane.I would be grateful for suggestions.
