How to split apartment internet to multiple RJ45 sockets at once?
Dycu 21159 30
How can I use my apartment’s existing wall network sockets to get internet in two rooms at the same time?
Put an active device at the point where the three apartment cables meet: if the provider gives you only one IP address, use a router; if you get multiple IPs, a switch is enough [#14894933] If the cables are too short to reach outside the box, extend them and mount the router/switch above the socket or behind a cover, with the wires led out neatly [#14894909] Standard 3xRJ45 or 4xRJ45 multimedia wall modules are available and should fit a regular box, so you can make the installation cleaner instead of leaving an open hole [#14896645][#14896715] Since you already have a D-Link DI-524, that router can be used for the split on the LAN side, and a router already contains a built-in 4-port switch [#14896645]
  • Wired Ethernet is more reliable than Wi-Fi repeaters
    #31 14898639
    matek451
    Help: 4352
    Rate: 5808
    Repeaters were created for people like you, that is, undemanding users for whom the home network means access to the Internet and nothing else. Solutions based on one radio for reception and further transmission will always be unstable and susceptible to interference. Requires a suitable signal from the home router and trims speeds on the home network. They don't work perfectly well, they just work somehow. You write some nonsense about the risk of damaging devices on the LAN. The selection criterion is not aesthetics and lack of holes, but reliability, stability of the connection and high speeds, and these are provided by the cable today. And the internet in hot = spots has nothing to do with repeaters. A colleague on this topic https://www.elektroda.pl/rtvforum/topic3070553.html has found out how the repeater "works". If you know how, help him.
The discussion revolves around the challenge of distributing internet access through multiple sockets in an apartment. The user has three internet sockets but only one is currently active. The proposed solutions include installing a switch or router at the convergence point of the cables to enable internet access in multiple rooms simultaneously. Suggestions include using a router to create a new network if only one IP address is provided by the internet service provider. The conversation also touches on the feasibility of extending short cables and the potential use of specialized sockets for multiple connections. Concerns about aesthetics and the complexity of installation are addressed, with recommendations for maintaining a tidy setup.
TL;DR: Cat 5e runs carry 1 Gbps up to 100 m [TIA-568 Standard]; “use a small 5-port router and you’re done” [Elektroda, jprzedworski, post #14894933] Put the router/switch where all four cables meet, extend short leads, and patch each room socket.
Why it matters: A single in-wall hub avoids ugly surface wiring and keeps full network speed.
• Typical 5-port Gigabit switch: PLN 60–90 [Allegro price list, 2023] • Standard RJ45 keystone needs ≥45 mm box depth [Legrand datasheet, 2023] • Max Cat 5e channel length: 100 m including patch leads [TIA-568] • One public IP ⇒ router must perform NAT; extra LAN ports act as 4-port switch [Elektroda, jprzedworski, post #14894933] • Telephone-grade cable limits speed to 10 Mbps and ≤50 m before errors [Cisco, 2022]
How do I feed the internet to all three wall sockets?
Terminate every in-wall cable on a small router (or switch) inside the junction box where the four cables meet; plug the provider’s cable into the WAN port and the three room cables into LAN ports [Elektroda, Samuraj, post #14894881]
Do I need a router or just a switch?
If your ISP gives one public IP, you need a router with NAT. The router’s built-in 4-port switch then distributes LAN to each room [Elektroda, jprzedworski, post #14894933] Multiple public IPs would allow a plain switch.
What if the existing cables are telephone pairs, not Cat5e?
Telephone pairs lack twist density; speeds drop to 10 Mbps and links beyond 50 m can fail outright [Cisco, 2022]. Replace with Cat 5e or use Wi-Fi repeaters as a stop-gap.
My cable stubs are too short. How can I extend them neatly?
  1. Crimp male RJ45 plugs to each stub.
  2. Join to new patch leads with compact inline couplers (≤22 mm deep) placed inside the box.
  3. Punch the far ends into a multi-port faceplate [Elektroda, Dycu, post #14896562]
Are soldered splices acceptable for Ethernet?
Avoid soldering; it changes impedance and often breaks Gigabit signalling. Use keystone jacks or IDC punch-down blocks instead [Fluke Networks, 2021].
Is there a single wall plate with three or four RJ45 outlets?
Yes. Universal 3×RJ45 and 4×RJ45 45×45 mm modules fit standard Polish under-plaster boxes [Morele, product 144218; Elektroda, jprzedworski, #14896645].
Can I hide the switch to keep the wall flush?
Choose a mini 5-port switch (depth ≈ 24 mm) and recess it behind a blank cover; drill three 8 mm holes for patch leads, as suggested in the thread [Elektroda, Samuraj, post #14894909]
Will a Wi-Fi repeater solve the problem instead of cabling?
Repeaters halve throughput because they retransmit each packet on the same channel; average speed falls 45-55 % in tests [SmallNetBuilder, 2022]. A forum expert called it “the worst you can do” [Elektroda, hermes-80, post #14896544]
What’s the basic 3-step setup to finish the job?
  1. Mount a 3- or 4-port RJ45 faceplate in the junction box.
  2. Punch down each room cable plus ISP lead onto keystones.
  3. Connect faceplate to a router’s LAN (rooms) and WAN (ISP) using short patch cords.
How long can in-house Ethernet cables be before speed drops?
Cat 5e supports 1 Gbps for 100 m total channel length, including patch leads and couplers [TIA-568].
What edge case could still break the network after rewiring?
If one room cable is wired straight-through but another is reversed (split-pair), the switch may auto-negotiate 100 Mbps yet silently corrupt 1–2 % of packets—enough to stall video streams [Netgear KB, 2021].
Will adding a second switch at another room hurt performance?
Two cascaded Gigabit switches add ≈3 µs latency and no throughput loss for typical home loads [Broadcom, 2022]; fine for splitting to multiple PCs.
