Instantaneous pressure switch under a step staircase - where to buy?
michael81 3957 11
What ready-made momentary normally-open sensor can I install under a stair step to trigger a short pulse?
A practical ready-made solution is usually a gate photo barrier or photocell, not a pressure mat under the step, because pressure mats/security mats typically stay active as long as pressure remains [#15002520][#16062404] One suggestion was to place ordinary gate photocells 20–30 cm before the step, at the bottom and top about 25 cm high, optionally hidden behind glass, so you get a precise short signal [#15038329] Another reply said that if the step itself can be made movable, that avoids the problem; otherwise a photo barrier for electric gates should meet the requirement [#15002667] If you can cut a hole of about 5 cm into the wall, the E18-D80NK sensor was also recommended as working well [#16034094]
  • #1 15002393
    michael81
    i have been looking for some time for something like a switch to mount under a step stair. Some sort of pressure mat or something similar. The switch is to be a momentary NO switch. I am getting tired of searching to no avail. Maybe some of you colleagues have a ready-made solution, a link to a ready-made product?
    ps. Any motion detectors have failed for me, unless someone knows where to buy a detector that has no hold when motion is detected just short circuits "momentarily".
    Regards
  • #2 15002451
    Michał_Wekta
    Welcome,
    you are right, the motion detector itself does not give information about the extinguishing of the light, therefore in such a case a timer for lighting is necessary. If we have such a switch connected to a motion detector and we set the motion detection for e.g. 1 minute, then if there is no motion within 1 minute, the light will switch off.
    I hope that I have helped you; if you are looking for a ready-made solution, please visit www.wekta.com.pl and familiarise yourself with our automation.
    WEKTA
    ul. Chrobrego 3A, Warszawa, 02-479 | Company Website: www.wekta.com.pl
  • #3 15002480
    michael81
    We didn't quite understand each other.... I just don't need the hold-up. It is supposed to work only in the field of view and disconnect immediately (just like a bell button).
  • #4 15002520
    Zbigniew 400
    Help: 283
    Rate: 793
    You need to attach a monostable circuit to the detector. And what should happen if someone is constantly in the detector field or standing on the step?
    You need to look for security mats or security devices for gates/ but it works the same as a detector, it holds the signal until the pressure disappears/.
  • #5 15002577
    michael81
    To give you an idea of what is involved :)
    I have installed stair lights in my house to be switched on when entering and exiting the stairs. The whole arrangement works nicely, but I have a problem with the automatic switching.
    The lights are supposed to switch on at the entrance and exit of the stairs. Unfortunately, if I have a hold on the switch and manage to ascend from the bottom to the top, the controller will treat such an event as the entrance of a second person and will not extinguish my lamps one by one, but all at once. Hence I need preferably a ready-made solution.
    Link to a video showing how it is done at my place:
    https://www.youtube.com/watch?v=t4TZrK5xaTQ
  • #6 15002622
    Zbigniew 400
    Help: 283
    Rate: 793
    Describe in literary terms how it should work.
    You go up.
    You go down.
    One person goes up, the other comes down.
    Remember that the sensor does not differentiate between directions.
  • #7 15002667
    kortyleski
    Help: 957
    Rate: 3855
    I know what you mean. But you are writing about a switch under the step. If the step is movable then there is no problem. Otherwise it's a photobarrier. One for electric gates will meet your requirements.
  • #8 15002948
    michael81
    With this barrier it's a cool idea. As for the moving stage, it's all good, but what kind of switch to use under it? So that it has arms and legs. I also have no idea how to mount this step so that it doesn't "rattle" over time :)
  • #9 15038329
  • #10 16034094
    RazieR
    if you have the possibility to "chisel" a hole of approx. 5 cm in the wall, I recommend:
    Sensor E18-D80NK.
    It works great for me.
  • #11 16037142
    ditomek
    Help: 24
    Rate: 230
    i suggest using a piezo sensor.
    They are cheap (£1-2) and can be connected to an arduino.
  • #12 16062404
    Marek J.
    Help: 526
    Rate: 950
    Perhaps a pressure mat?
