How do I switch off the external socket when arming the Satel Verso 15 alarm?
Maciek Sz.12 2232 8
  • #1 15179115
    Maciek Sz.12
    Level 4  
    Rate: 14
    Hello, when renovating the boiler room I would like to make myself switch off the outside socket when arming the alarm using a Satel Verso 15 alarm and relay. Because I have reason to believe that someone has been using the socket while I am away. I would like to know how I could do this. I have empty conduits between the control panel and the switchboard and when I renovate I can replace/add a cable to the socket outside. Could you advise me if the socket should be changed or if I should use a contactor?
  • #2 15182195
    sbartos
    Help: 62
    Rate: 153
    Hola!
    In my opinion relay plus contactor on TS35 so called "silent used in hospitals" NC.
    Greetings
    S.
  • #3 15182659
    Maciek Sz.12
    Level 4  
    Rate: 14
    That is, for example, such a combination:
    RM85-12V relay
    Hager 1NC 25A contactor
    Isn't there some such ready-made socket with a contactor? And I am also concerned that it should not draw a lot of current during "standby".
  • #4 15183009
    sosarek
    Help: 9320
    Rate: 15528
    Installation is one thing, the question of appropriate control panel software is another....
    Z
    Pka, Poznań, 60-850
  • #6 15243283
    bartek_p
    Help: 128
    Rate: 195
    The switch installed in the boiler room, connected to the socket, draws the least amount of current.
    If you need it, you turn it on and that's it.
  • #7 15245167
    sbartos
    Help: 62
    Rate: 153
    Hola!
    How about some SSR?
    Greetings
    S.
  • #8 15252807
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    The external socket is rarely used, just install a separate fuse for this circuit and switch it on when needed.
    If you want to use an alarm, set the free output to the standby indicator and connect the coil of a relay (e.g. RM 84 16A) to it, and on the C/NC contacts connect this socket.
  • #9 15255367
    bartek_p
    Help: 128
    Rate: 195
    A relay is not suitable for this application.
    A contactor must be used. Contrary to appearances, these are two different devices.
