Hanseatic/Amica EBS 13230 E Oven: Error in Geco Controller, 2GB Micro SD Card Issue, Austria
Eleels 12561 1
  • Corrupted 2GB microSD card filesystem in Geco controller
    #1 15182571
    Eleels
    I have a problem with an oven, and I live in Austria, and don't speak Polish language, so I have to write
    in English. (Sorry for any inconvenience)
    This oven is a Hanseatic/Amica (Amica EBS 13230 E) Product and has a Geco Controller
    device with a micro - SD - Card which is defect.
    I managed to open the oven and took out the micro - SD Card which is a 2GB micro SD.
    Unfortunately that's it and I don't know how to go on ...
    The Cardreader accepts the SD, but says "No known file System" .. so I can't read the card and also don't know which software I need.
    Can anyone in this forum help me on that ?
    Can you help me to solve the problem at all?
    On the Controller is written:
    Indeks Amica: 8050035
    Kod Geco: PG351.02
    -3E8 NS: 3347 Data Prod.: 09-12
    Un=12V lmax=400mA
    The Data of the Oven is:
    The Hanseatic Variation Data:
    Typ: 1143.3TpYDQVRXSp
    ArtNr.: 780490
    EN60 335-1/2-6
    Prod.Code 53 646
    Seriennummer.: 08095364626112
    But it's obviously the Same as the Amica EBS 13230 E
    Thank's in advance and sorry again for any inconvenience.
    Eleels
  • Oven SD-card fault persists after reflashing
    #2 15257590
    byq84
    Rate: 8
    I have the same problem with my oven Amica EBI 81074, I did a flash on a new SD card but the problem still persists. I think the issue is related to a bad SD Card, I will try to flash it once again this week. I don't know if your oven is the same as mine, there is a manual in another Polish forum on how to do it.
    http://www.elektroonline.pl/a/8492,Piekarnik-AMICA-EBI81074-error-card-SD-naprawa
