Peugeot 508 1.6 e-HDI 115km: Correct FAP Fluid Refill - Fluid Recommendations & Lexia/Proxia Guide
dayanes 89700 4
  • #1 15184748
    dayanes
    Rate: 91
    Hello. I have a question, it concerns the refill of the FAP burnout aid in the Peugeot 508 1.6 e-HDI 115 km.
    How to perform this procedure correctly, what fluid to buy and what needs to be done with a diagnostic computer for the whole operation to be successful.
    I have a dedicated Lexia / Proxia interface. But I haven't done it yet and I would like to make every effort not to spoil anything, this is a new car after all. I will be very grateful for any specific tips. greetings
  • #2 15184827
    cezars65
    Help: 53
    Rate: 282
    This fluid is called ELOYS and is dedicated to the PSA group cars. It cannot be replaced with another brand of fluid. You can buy it at ASO.
  • #3 15184833
    marcias
    Help: 18
    Rate: 87
    Enter at least this topic, you have everything described here https://www.elektroda.pl/rtvforum/topic1965867.html
    In short, buy Eolys fluid, fill the tank with fluid, start the Diagbox and reset the FAP counter (you will probably find this option in the FAP module in the "programming" section)
  • #4 16372789
    PrezesBednarz
    Rate: 8
    Hello, I am currently working on the topic of low fapa fluid level in the 5008 1.6 HDI 2012.
    The clip on the connector is white.
    I read the file from the post above and there is only a green or blue connector. in the case of DPX 42 there is no completed table in the "color of the pin"
    The tank is stiff. I have already confused which fluid should be there.
    And the question is whether KTS will handle the refill procedure, or is the minimum Lexia needed?
  • #5 16964800
    wmk16
    Rate: 18
    Hello. I will stick to the topic. I added liquid to 508sw 2.0 140 2013. and I can't get any refills. I deleted the errors in the engine cal. After inserting the fap tank replacement, but when I enter the refill, it causes me the same errors with a small amount of additive each time. I don't quite know what the procedure is in 508 from this year. In 407 I had a different than in c5, I know that the cars have a slightly different procedure for entering refills and when I try to enter in 508 I have no explanation / instructions.
