ALUPROS YYGL35 actuator limit switch shifts after use—how to fix end stop drift?
gharalion 8109 3
  • #1 15256989
    gharalion
    Help: 6
    Hi guys. I am putting in motors for external roller shutters and have a problem adjusting the actuator. Well, the ALUPROS YYGL35 actuator has two allen screws for adjusting the ends - standard. I adjusted the bottom end stop, it stops nicely, adjusted the top end stop - same thing. However, after a couple of times of opening and closing the roller shutter, the upper end stop works earlier and earlier. More and more of the roller shutter is visible when it is tripped. Has anyone had a similar problem and know how to solve it?
    Regards
  • #2 15262388
    bartek_p
    Help: 128
    Rate: 195
    How do you control this roller shutter?
  • #4 15264226
    bartek_p
    Help: 128
    Rate: 195
    If there are two roller shutters on one switch this can also happen.
