Washing Machine Comparison: Bosch Serie 4 VarioPerfect WAE24441PL vs Samsung WF70F5E0W2W EcoBubble
GoBladeer1 60954 32
Which is better: Bosch Serie 4 VarioPerfect WAE24441PL or Samsung WF70F5E0W2W, and does the Samsung have a detachable drum, replaceable bearings, and EcoBubble?
Forum users lean slightly toward the Samsung for its replaceable drum bearings, but several people also considered Bosch WAE models solid choices. One user chose the Samsung specifically because the bearings are replaceable, although another warned about long wash times, low washing temperatures, and a large drum opening [#15307776][#15307548] EcoBubble is not a separate mode; the machine foams the detergent in a tank first and then sends it into the drum, and one user said it eliminated white streaks on clothes [#15311419][#15310929] For Bosch, the WAE series was described as having a detachable drum/tank and replaceable bearings, and one owner reported no problems after 3 years with a similar WAE2449FPL [#15534823][#17847481]
  • #31 17641048
  • #32 17847481
    GoBladeer1
    Rate: 20
    Welcome back. I wanted to write that after 3 years of using the "Bosch VarioPerfect WAE2449FPL" washing machine, I have no problems with it, no breakdowns.
    Overall, I am happy with it
  • #33 17904110
    Kayu
    BOSCH WAS24444PL after 5 years (purchased in 2014) has been making holes in clothes for some time, I'm wondering whether to repair (just what?) Or replace.
    Edit - "foreign" fault in the drum.
The discussion revolves around the comparison of two washing machine models: Bosch Serie 4 VarioPerfect WAE24441PL and Samsung WF70F5E0W2W EcoBubble. Users express concerns about the Samsung model, citing long washing times and issues with drum design, while others highlight the EcoBubble technology's effectiveness in preventing detergent residue. The Bosch model is favored for its reliability, with users noting features like replaceable drum bearings and an extended warranty option. The Bosch washing machines are praised for their functionality, including a quick wash program and accurate display of washing time. Some users also mention the WAN series from Bosch, clarifying that both WAN and WAE series have removable drums, but the bearing replacement process differs. Overall, Bosch is recommended for its performance and durability, while Samsung's reputation is mixed.
TL;DR: 7 kg Bosch Serie 4 owners report zero breakdowns after three years (n = 1) [Elektroda, GoBladeer1, post #17847481]; Samsung EcoBubble “leaves no white streaks” [Elektroda, Svetherus, post #15310929] Bosch cycles average 120 min but can halve with VarioPerfect [Elektroda, Anonymous, post #15351609] Both lines have split drums; Bosch WAE bearings are user-replaceable, WAN tubs cost ~PLN 450 if worn [Elektroda, Przemeek1988, post #15917359]
Why it matters: choosing serviceable drums cuts future repair bills.
Does the Samsung WF70F5E0W2W have a detachable drum and replaceable bearings?
Yes. Owners report split plastic tubs with separate bearings and seal that can be renewed [Elektroda, majster222, post #15307776]
How does EcoBubble work, and can I disable it?
Detergent mixes with air and water in a small chamber, creating foam before entering the drum; this improves dissolution and prevents residue [Elektroda, Svetherus, post #15311419] You can deactivate it via the hidden menu:
  1. Start any program.
  2. Hold Temperature + Options ≈ 3 s.
  3. Wait for the EcoBubble icon to turn off. [Elektroda, lottusOpole, post #16026407]
What exactly is Bosch VarioPerfect?
VarioPerfect adds two buttons: SpeedPerfect halves wash time, EcoPerfect cuts energy by up to 30 % while extending time [Bosch, User Manual].
Is an extended warranty on Bosch worth the money?
If labour costs in your area exceed PLN 270 for a motor or pump swap, a 5-year add-on pays off; otherwise skip, because user-replaceable bearings lower repair risk [Elektroda, majster222, post #15307776]
LED display vs LED program indicator—any difference?
Display models show remaining minutes; indicator-only versions light fixed icons for phase progress. No impact on wash quality [Elektroda, Anonymous, post #15317843]
Are WAN bearings as easy to replace as WAE bearings?
No. WAN uses a split tub, but the bearings are moulded into the rear half; you must buy the whole rear tub (~PLN 450) [Elektroda, Przemeek1988, post #15917359] WAE bearings can be replaced individually for ~PLN 60 each [Typical parts list].
Which motor is better: EcoSilence Drive or traditional brushed?
Brushless EcoSilence cuts noise by ~10 dB and eliminates brush wear, extending lifespan [Bosch, 2022]. Brushed motors are cheaper but hum during spin and need brush replacement every 5-7 years [Elektroda, Anonymous, post #15351609]
How long is a standard cotton cycle on Bosch WAE, and how do I shorten it?
Default Cotton 40 °C lasts about 120 min [Elektroda, Anonymous, post #15351609] Press SpeedPerfect to shave roughly 60 min off while raising energy use slightly [Bosch, User Manual].
