Frog Lift Selection: Top Manufacturers, 2T Load Capacity, & Budget of PLN 200-500
40743 15
  • #1 15376916
  • #2 15377636
  • #3 15377855
    adamblonsky 2012
    Level 19  
    Help: 23
    Rate: 48
    And what kind of equipment do you want to lift with this?
  • #4 15378322
  • #5 15378986
    pepe150
    Level 36  
    Help: 288
    Rate: 935
    I bought a tool store (Made in China) from AW-Tools (AW Tools store).
    Plain, not low profile 2T. No problem BMW E39 532 picked up, Toyota Yaris, Peugeot 306, Opel Corsa, Seat Leon.
    At work, I have a low-profile Yato YT-1720 2T, and it also raised a lot, Citroen C5 X7, Kia Carens, Kia Carnival - even Chrysler Town & Country 3.8 without a problem.
  • #6 15380823
    adamblonsky 2012
    Level 19  
    Help: 23
    Rate: 48
    As for passenger cars, a low-profile 2t is enough.
    I have marpol china and I am very happy on the allegro for about PLN 120.
    stable, raises high and the price is great.
  • #7 15381477
    andrzej20001
    Help: 1572
    Rate: 6624
    A small yato is also ok, it is low.
  • #8 15382502
  • #9 15382504
    andrzej20001
    Help: 1572
    Rate: 6624
    Well, low and raises, and cheap.
  • #10 15382652
    bearq
    Help: 414
    Rate: 1602
    I used to use such a ladybug supermarket, it swayed terribly under the weight, the lift lifted terribly reluctantly and had a tendency to slowly fall. It probably cost about PLN 100 but the money is down the drain. Isn't it the same with Yato?
  • #11 15383000
    marekwodniak
    Help: 14
    Rate: 193
    It is better to add and buy 2.5 tons. I had such a frog for PLN 80. It raised the plunger 5 times and popped out. Now I don't believe her and gives mare mare.
  • #12 15383269
    bula17
    Help: 52
    Rate: 295
    DON'T buy Facom I gave 800 3 times on complaint and continued screeching when picking up.
  • #13 15383330
  • #14 15383391
    bula17
    Help: 52
    Rate: 295
    I was shocked myself, when after a week there were squeals of shame in front of the client I sent back to Warsaw, they said that nothing was happening and they lifted without a load and so we sent them back 3 times and they made less squeaks but squeaks.
    I also thought that I would pay 2x as much as the cut jack will be ok. One thing that is cool is the wheels are quiet when pulling.
    And you pay attention when buying a set of wheels that the lift is stable for a specific brand, unfortunately I will not help.
  • #15 15383945
    pepe150
    Level 36  
    Help: 288
    Rate: 935
    YT-1720, something squeaks when picked up, but does not lower itself.
    Needed for some cars.
    I do not know how much time is left, but for 5 years nothing happened with him that a person would be afraid.
  • #16 15384049
    marekwodniak
    Help: 14
    Rate: 193
    2.5 T raises low cars and as much as 36 cm.
✨ The discussion revolves around selecting a "frog" type lift with a load capacity of 2T, within a budget of PLN 200-500. Key considerations include lifting height, arm length, and stability. Users recommend low-profile models for passenger cars, with specific mentions of brands like Yato and Marpol. The Yato YT-1720 is highlighted for its performance and stability, while concerns are raised about cheaper models' reliability. Some participants suggest opting for a 2.5T lift for added safety, despite the budget constraints. Negative experiences with the Facom brand are noted, emphasizing the importance of quality and brand reputation in lift selection.
