Decent 2-Ton to 3-Ton Jack/Jack Frog for Amateurs: Quick Lifting, Safety & Price Range
wemibo 8493 3
  • Recommend a 3-ton jack for faster lifting
    #1 17122541
    wemibo
    Rate: 28
    I am currently using a frog type lift 2 tonnes. In addition to the advantages - cheap, lifts and holds, light - has one major disadvantage - it is free. This means that I have to pump several times to lift the car. Being at the mechanic's, he used a jack-frog to lift the car (wheel), just a few times with a lever. I use the jack to change wheels, blocks, etc. in passenger cars.
    Currently, there is a lot to buy jackets, a large price range. A question for people in the subject - would a good purchase be a cheap but 3 ton jack - would it be faster above all? I presume that such a jack will also be safer, it will last longer, easier to use (I mean a change lowering / lifting by turning the lever without removing it). But above all faster.
  • #3 17125243
    wemibo
    Rate: 28
    However, I would like to buy a 'classic frog', only decent for an amateur.
  • #4 17126091
    dizba
    Help: 239
    Rate: 807
    Then buy one: LOW-PROFILE LIFT FROG BJC 3T 75-500mm
