Best Double-Leaf Gate Drive (2.25m Width, 1.3m Height, 80kg) Under PLN 2000: Recommendations & Tips
berni 2007 10293 4
  • #1 17409147
    berni 2007
    How to buy a double-leaf gate drive, one gate width 2.25, height 1.30, weight about 80 kg (we don't know anything about it), max price PLN 2000. Best Double-Leaf Gate Drive (2.25m Width, 1.3m Height, 80kg) Under PLN 2000: Recommendations & Tips Best Double-Leaf Gate Drive (2.25m Width, 1.3m Height, 80kg) Under PLN 2000: Recommendations & Tips
  • #2 17412645
    tomek201
    Help: 9
    Rate: 61
    This is a question for gate automation, not the selection of a set, because it has a neighbor and it comes. Buying a good set is not just the price. Proper assembly, setting the ABC triangle for the correct operation of the servomotors, closing limiter, good matters and configuration is not hop siup if you want to have drives for years.
    You have fixed hinges, large distances from the post, a ventilated gate, but also a sail in winter. If you assemble a set for 1500 zlotys, even Faac, you will be satisfied.
  • #3 17417501
    karmad82
    Hello, I recommend the set of the Polish company elektrobim model etm-02 affordable price 1,400 PLN and you are able to mount it yourself. If you have technical questions or choose automation, I also recommend Mr. Damian - contact details in the contact tab on the company's website.
    Moderated By Marek J.:
    3.1.10. Do not advertise websites or services in any form.
  • #4 17417788
    Marek J.
    Help: 526
    Rate: 948
    karmad82 wrote:
    Hello, I recommend the set of the Polish company elektrobim model etm-02 affordable price PLN 1,400
    Ta ..., Polish ??? People, stop wrapping the bush and cheat your compatriots! These are products from China bought in bulk for a fraction of the sale price ... At first, even all the equipment was from China, but it did not work and many buyers remained with "hand in the potty" ...
    https://pt.aliexpress.com/item/Auto-Electric-...te-Motor-With-Remote-Control/32812587838.html
    Even actuators for indoor work were sold (maybe even still) as actuators for external entrance gates. Browse the forum and Chinese portals a bit and the whole truth will come out ...
    I have nothing against products from China, as long as there is a resident there or a control caring about the quality of the products. There are many companies that design products themselves and outsource workmanship in China with product care, but this is not the example ...
  • #5 20365190
    Darek0026
    Help: 220
    Rate: 378
    Now the CAME ATS drive is on top, it should come easily. Perfect value for money
