Pros and Cons of Using Universal Spray Paint on Old Keyboard Rubber Buttons
Maciek1988x 16875 3
  • #1 15852419
    Maciek1988x
    I pulled an old keyboard out of the basement. I've taken it apart and cleaned it thoroughly, but the motley rubber buttons annoy me a bit. Is painting them black with universal spray paint a good idea? Will the paint chip or come off when pressed?
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    Much depends on the hardness of this rubber and the intensity of use. It is important to thoroughly clean / wash these keys before painting. Paint with the thinnest possible layer. So that the material is fully covered. The effect will be satisfactory for a long time.
  • #4 15869223
    Maciek1988x
    Thank you for your help. Finally, I painted the buttons with spray paint from Obi, just to test. It took two coats but the paint seems to be holding up.
