Minimum Compression Pressure for Naturally Aspirated Diesel Engine Operation
dharma123 61350 10
What is the minimum compression pressure for a naturally aspirated diesel engine to operate?
A naturally aspirated diesel should have at least about 20 bar of compression to be considered operable, while around 26–28 bar is a more typical healthy value and about 26 bar is cited as enough for it to fire normally [#16111848] [#16105481] [#16103158] For example, URSUS C-360/C-330 engines are given a nominal new-engine compression chamber pressure of 2.8–3.2 MPa, which is 28–32 bar [#16103239] In that same example, a difference greater than 35% from the reference value indicates the need for engine repair [#16103239]
  • #1 16103132
    dharma123
    Help: 5
    Rate: 96
    I am looking for information on what is the minimum pressure for diesel engine operation. Ordinary naturally aspirated.
  • #2 16103154
    Alfred_92
    Help: 148
    Rate: 706
    How much did you get?
  • #3 16103158
    ociz
    Help: 1379
    Rate: 3486
    At least to get it to fire? About 26 bars.
  • #4 16103186
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    At 26 it fires normally, I fired vw 1.6 which had 9, 16, 18, and 19, not in that order of course. There was no frost, the candles were heated for 2 minutes because even the self-starter did not want to start on zinmo, then the self-starter with air from the heat gun and a minute on the starter with symptoms of catching and gas in the floor and as soon as he managed to pull himself, he arrived to replace the engine ☺
  • #5 16103239
    manekin12
    Rate: 9
    Hello. From what I remember, most naturally aspirated diesel engines are installed in agricultural machines and tractors, but not only. Not all engines, even naturally aspirated ones, have the same compression pressure. I will give you only the example of our well-known engines from the URSUS C-360 and C-330 tractors. The pressure in the compression chamber for one engine and the other is 2.8-3.2 Mpa (nominal pressure, new engine). The difference between the reference values and the results of compression pressure measurements exceeding 35% of the reference value indicates the need for engine repair.
  • #6 16104654
    dharma123
    Help: 5
    Rate: 96
    Specifically, I meant how much I would have to boost the gasoline engine to be able to power it with diesel fuel.
  • #7 16104895
    sq7fbr
    Help: 18
    Rate: 51
    forget it. By adding petrol, you will overload the piston-crank system, i.e. connecting rod bearings, main bearings and piston pins. The durability of such an engine will be very short.
  • #8 16104963
    Xantix
    Help: 686
    Rate: 1657
    Well, in this case, you should probably talk about the compression ratio. Roughly speaking, for the engine to work (at least in theory) on ON, you would have to increase the compression ratio almost twice. And this, as the colleague above said, will greatly burden the structural elements of the engine. Diesel engines have a much more massive construction than petrol engines because they have to withstand much higher operating pressures.
    Besides - to make such a modification in a simple engine, you would have to replace all the accessories of that engine (because the power supply of a petrol and diesel engine is radically different). To sum up, such a modification will encounter so many technical problems that in my opinion it is unprofitable.
  • #9 16104995
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    The first Golf MK I engine from '74 1500 petrol and diesel were structurally identical, block, shaft, cranks, only the pistons and heads were different
    Nevertheless, forget about converting any gasoline engine to diesel
  • #10 16105481
    robokop
    Help: 1763
    Rate: 6372
    So far, most engines have been made on the same block and crankshaft - old Opel, Renault, etc. I have never looked at the connecting rods themselves in terms of petrol / diesel differences. Pistons, of course, are different - much heavier, with thicker bottoms, walls and more massive pin seating, often with embedded steel inserts. The head is a whole different story. Especially in the middleman. In any case, it's easier to build a diesel engine than to convert a gasoline one. Unless it's supposed to be something similar to fairy tales about WSK motorcycles riding on ON?
    A gasoline engine is usually around 13-15 atm, below 10 atm the wear limit is assumed. Diesels - 26-28 atm, limit consumption below 20 atm. So as you can see, you would have to double the compression. Added to this is the shaping of the chambers in the pistons to achieve swirling - not such a simple matter.
  • #11 16111848
    dharma123
    Help: 5
    Rate: 96
    I assume a minimum pressure of 20 bar. I consider the subject exhausted.
The discussion centers on the minimum compression pressure required for the operation of naturally aspirated diesel engines. It is noted that a typical minimum pressure for these engines is around 26 bars (2.6 MPa) to achieve ignition. Specific examples from agricultural machinery, such as the URSUS C-360 and C-330 tractors, indicate nominal compression pressures of 2.8-3.2 MPa for new engines. The conversation also touches on the impracticality of converting gasoline engines to diesel due to the significant differences in compression ratios and structural requirements, with diesel engines generally requiring much higher pressures (26-28 atm) compared to gasoline engines (around 13-15 atm). The consensus is that modifying a gasoline engine to run on diesel would lead to excessive wear and potential failure of engine components.
