The central hoover switches itself on when the light is switched on - what could be the cause?
endrjukatowice 1767 5
  • #1 16106782
    endrjukatowice
    There is this problem with a central hoover in a detached house. Sometimes it wants to start by itself. It is also triggered by turning on e.g. a light. The cables from the control contacts in the sockets are ok. I have also checked with an inductor to see if there is a puncture from the electrical system. Could it be induction from electrical cables running too close? When I switched off the electricity throughout the house at the fuses outside in the box and applied voltage from an extension cord connected to a neighbouring house everything was ok. All I had to do was switch on the fuses and the hoover started trying to start again. I should add that the box where the control wires converge and the hoover itself are mounted right next to the electrical distributor inside the house.
  • #2 16106849
    jaszczur1111
    Help: 173
    Rate: 494
    Perhaps blocking the wires from the control module with a capacitor of say 100nF would help ?
  • #3 16106979
    endrjukatowice
    Switch between the wires of the control cable?
  • #4 16108244
    jaszczur1111
    Help: 173
    Rate: 494
    This is what I would do. Check what the voltages are still there. My guess is 5-12V
  • #5 16108951
    endrjukatowice
    12V. Thank you I will try to do that.
  • #6 16141764
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    endrjukatowice wrote:
    12V. Thank you I will try to do so.
    And what did mate help?
