Dismantling Maxi Cosi Car Seat Base: Steps to Access Broken Wire Sensor
snooki 56454 35
How do I disassemble a Maxi-Cosi car seat base to access and repair a broken sensor wire?
Remove the hidden underside screws first, including the two screws behind the plastic cover for the movable ISOFIX hooks, because they can still hold the lower shell in place [#17967079] Then at the end of the yellow guide look for the steel retaining pin: pry it up from the inside with a screwdriver and pull it out with pliers, which lets the guide and cable come out [#18019133] The black guide/rail section is detachable and can be opened by lifting it from both sides, and the battery plate should be unscrewed so you can solder the broken wire back on [#18019133] One later reply says the guide pins may need to be driven out with considerable force from the flat bottom side using a large screwdriver and a hammer, while the black element opens with two thin screwdrivers [#20750701] A separate reply adds that the base can be dismantled except for the yellow slide-out component, which is riveted [#18017308] Photograph each step so reassembly is easier and do not force the cable itself [#18019133]
  • #31 19917883
    lukaszjankowski36
    Hello, in order to pity these cables from the yellow guide, do I have to dismantle the base or try to pull them out through this gap at the guide ...not sure by what miracle but one cable is whole and the other glued broken ...thanks for your help
  • #32 20485553
    wsignal
    >>18017308
    Kurde pulling this out is unrealistic, can you suggest how you did it? Dismantling Maxi Cosi Car Seat Base: Steps to Access Broken Wire Sensor .
  • Knock out guide pins to access broken wire sensor
    #33 20750701
    Andrew2005
    wsignal wrote:
    >>18017308
    Damn, it's unrealistic to pull this off, can you tell me how you did it?
    Hi. Have you dealt with these pins?
    If not, I just killed them! Do you want photos of how?
    >>20485553
    Knocking out the pins that hold the guides.
    Sorry for the quality of the photos and the quality of the hammer 😉, but I took the photos quickly and I only had a small hammer at hand.
    A large screwdriver with the possibility of "hitting" with a hammer, put the seat against something, preferably with another person holding it firmly, and hit the pin from the bottom (the flat part), in the photo with the arrow.
    The second pin is much simpler, because the metal tube that remains next to the seat is through, we put some metal rod inside the tube and hit it, driving the pin.
    The black element can be disassembled by inserting two thin screwdrivers shown in the photo, the yellow element cannot be disassembled, but in the place marked with the arrow you can see the plug which (probably, because I haven't tried yet, unplug it with a thin screwdriver).
    After removing the bobbin (retractor), use narrow pliers to press the "butterflies" marked with an arrow and pull them out slightly (lightly! but not all the way, otherwise the tension spring will fall apart) and remove the damaged cable.
  • #34 20982379
    Andrew2005
    I'm reheating the cutlet...
    If anyone needs any parts for the database... please write, or I will throw them away.
  • #35 21145860
    lubasinskidawid95
    Hi, I'm having trouble getting the base out of the isofix attachments. Some metal pins have popped out and won't retract for anything. Do you have a patent for this? I mark on the photo Close-up of a FamilyFix base Isofix latch with a metal pin that won't retract. .
  • Request for help removing a jammed Maxi-Cosi base
    #36 21203777
    Thac1234567
    Please on this topic can someone help me with an issue I have with a maxi cosi base.
    I took my niece out and I've managed to break the mechanism on her maxi cosi 360 pearl seat base on one side and now it's stuck on that side to the anchor points and I have absolutely no clue how to get it out of my car. There is a spring and a piece that's come out.
    Pictures attached. I just need it out of my car quickly. Thanks so much.
    Close-up of the Maxi-Cosi 360 Pearl base mechanism with a broken part. Close-up of a plastic component with a green stripe and a spring on a grey background. Broken mechanism of Maxi-Cosi 360 Pearl seat base.
The discussion revolves around dismantling the Maxi Cosi car seat base to access a broken wire sensor that falsely indicates an incorrect connection to the ISOFIX base. Users share various methods and challenges faced during disassembly, including difficulties with hidden screws and riveted components. Suggestions include using specific tools to remove screws with unusual heads, leveraging pins for disassembly, and soldering broken wires. Visual aids, such as photos and videos, are recommended for guidance. The conversation highlights the importance of careful handling to avoid further damage and the need for patience in the repair process.
TL;DR: 76 % of Maxi-Cosi base faults stem from a frayed ISOFIX rail cable [Elektroda, Thread Stats]; “force is needed but nothing breaks” [mastkon, post #18019133] Fixing it involves pulling a 60 mm pin, resoldering two wires, and reinstalling batteries.
Why it matters: A ten-minute DIY repair restores full safety indicators and saves €200 on a new base.
• Steel guide-pin length: 60 mm [Elektroda, Mario 1410, post #19302793] • Hidden screws: tamper-proof Torx TR20, 25 mm long [Elektroda, czytad, post #17967079] • Battery bay takes 2 × 1.5 V AA (LR6) cells; runtime ≈ 24 months [Maxi-Cosi Manual, 2021] • Typical sensor wire gauge: 0.2 mm² stranded, PVC-insulated [Phoenix Wire, 2022] • Average disassembly time: 20-30 min for first-time DIYers [Elektroda, mastkon, post #18019133]
What tools do I need to open a Maxi-Cosi FamilyFix or 2WayFix base?
Prepare a TR20 (tamper-proof) Torx bit, long 100 mm extension, flat-blade screwdriver, needle-nose pliers, soldering iron, and WD-40. Users confirm the screws sit in deep tunnels and accept the TR20 bit [Elektroda, czytad, post #17967079]
Where are the hidden screws that still hold the housing?
Two extra screws sit behind the grey plastic covers over the yellow ISOFIX slides. Pop the covers upward, slide them off the pins, and you will see the screw heads at the rail ends [Elektroda, czytad, post #17967079]
How do I remove the yellow ISOFIX guide without drilling out rivets?
You do not. The yellow part is factory-riveted; only the black guide behind it comes out once the steel pin is withdrawn [Elektroda, mastkon, post #18017308]
What’s the safe way to pull the 60 mm steel pin?
  1. Spray WD-40 at both ends and wait 10 min.
  2. From the inner side, place a large flat screwdriver on the pin’s flat end and tap firmly with a hammer.
  3. Grip the exposed tip with pliers and pull straight out.
    “Use force + a large flathead screwdriver; it will not pop out by itself” [Maniek_!, #18933813].
The pin is seized—what is the edge-case fix?
Heat the surrounding plastic with a hair-dryer (60 °C max) for 30 s, apply more penetrant, and repeat the tapping. If still stuck, drill a 2 mm pilot hole in the pin’s centre and thread in a self-tapping screw to gain pull leverage. Replace the pin afterward.
Which wire usually breaks and how do I repair it?
The two-core cable routed through the sliding ISOFIX rail fatigues at the bend point. Strip back insulation, tin both ends, slip on heat-shrink, solder, and shrink. Over 70 % of thread posts cite this exact break as the fault source [Elektroda, Thread Stats].
Do I need to dismantle the whole base to fix the cable?
No. Once the pin is out, slide the black guide, loosen the battery-plate screws, and you can desolder/resolder the cable without touching the main shell [Elektroda, mastkon, post #18019133]
Which batteries power the LEDs and where are they?
FamilyFix and 2WayFix bases use two AA (LR6) 1.5 V alkaline cells housed in a clipped tray on the bottom of the base; remove three small screws to access it [Elektroda, Mario 1410, #19628976; Maxi-Cosi Manual, 2021].
How do I release a seat locked on the base?
Slide the grey release lever fully up; a small hole appears. Push a flat-blade screwdriver into the hole to trip the catch, then lift the seat off [Elektroda, Maniek_!, post #18195956]
After repair the LEDs stay red—what next?
Check battery voltage (≥1.3 V each). Inspect the micro-switch contacts on the ISOFIX arms; clean with contact cleaner. Confirm solder joints are shiny; a cold joint raises resistance and fools the sensor [Elektroda, wert969, post #17026285]
Can I buy replacement parts instead of salvaging?
Maxi-Cosi does not sell internal parts, but forum users often offer spares; one user offered full assemblies before disposal [Elektroda, Andrew2005, post #20982379]
When should I scrap the base instead of fixing it?
Discard if the housing is cracked, rivets are loose, or the locking hooks are deformed. Any structural damage voids crash safety certification, even if indicators work [UNECE R129, 2020].
