Netis WF2411 Router Configuration Issues with Multimedia Polska Internet
bartekziom5 7197 16
How can I configure Wi‑Fi on a Netis WF2411 router connected to Multimedia Polska internet, and could the router be faulty?
Configure the Netis from a computer by cable, connect the provider modem/router to the Netis WAN port, and check the STATUS tab to confirm the WAN and LAN addresses are assigned correctly [#16177927][#16177992][#16178100] The wireless security was set to WPA/WPA2-PSK, and the PC received a 192.168.5.2 address with gateway/DHCP server 192.168.5.1, so the basic network side looked normal [#16178802][#16178226] If the router is connected correctly but no device can see the SSID, that points more toward a faulty unit than a setup problem [#16178862]
  • #1 16177890
    bartekziom5
    Hello. I have a problem, I bought a Netis WF2411 router and I can not configure Wi-Fi in any way. I would like to add that I have internet with Multimedia Polska, is it possible that the router has some manufacturing fault? Thank you in advance for your help.
  • #2 16177895
    jimasek
    Help: 3783
    Rate: 2681
    Do you have access to the router's configuration? Preferably cable to a computer and then you configure Netis.
  • #3 16177902
    bartekziom5
    So on the site I have to choose either fast configuration or advanced. None of them work.
  • #4 16177927
    jimasek
    Help: 3783
    Rate: 2681
    Kablowo, do you have access to the Internet? Netis hooked through the WAN port to the modem provider? What does the Router Status tab show?
  • #5 16177983
    bartekziom5
    The router is wired to the router status Netis WF2411 Router Configuration Issues with Multimedia Polska Internet
    jimasek
    Help: 3783
    Rate: 2681
    bartekziom5 wrote:
    The router is wired as a router status
    To what port? I am interested in the entire STATUS tab and the addressing of WAN and LAN on the router,
  • #7 16178100
    bartekziom5
    The router is connected to the WAN port, here's the status Netis WF2411 Router Configuration Issues with Multimedia Polska Internet
  • #8 16178226
    jimasek
    Help: 3783
    Rate: 2681
    Everything looks good here. How have you set up Netis security for your wireless network. What does ipconfig / all show when you're connected to a wireless network - link
  • #9 16178802
    bartekziom5
    When it comes to security, I have set to WPA / WPA2-PSK, and here's what jumped out in cmd
    Windows IP configuration
    Host name. . . . . . . . . . . : Win-7
    The suffix of the primary DNS domain. . :
    The type of node. . . . . . . . . . . . : Hybrid
    IP routing enabled. . . . . . . : No
    WINS Proxy server enabled. . . . : No
    Ethernet card Local connection:
    The DNS suffix of a specific connection:
    Description. . . . . . . . . . . . . . . : Realtek PCIe GBE Family Controller
    Physical address. . . . . . . . . . : 50-E5-49-3A-87-9C
    DHCP enabled. . . . . . . . . . : Yes
    Autoconfiguration enabled. . . . : Yes
    The IPv6 address of the local connection. : fe80 :: 3815: eb81: d104: 3f9e% 11 (Preferred)
    IPv4 address. . . . . . . . . . . . . : 192.168.5.2 (Preferred)
    Subnet mask. . . . . . . . . . : 255.255.255.0
    Lease obtained. . . . . . . . : January 6, 2017 5:22:21 PM
    The lease expires. . . . . . . . . : January 6, 2017 at 23:27:53
    Deafult Gateway. . . . . . . . . . 192.168.5.1
    DHCP server. . . . . . . . . . . 192.168.5.1
    DHCPv6 IAID. . . . : 240182601
    DHCPv6 client DUID: 00-01-00-01-1F-55-EE-DB-50-E5-49-3A-87-9C
    DNS servers. . . . . . . . . . . 217.172.224.170
    89.231.1.206
    8.8.8.8
    192.168.5.1
    NetBIOS via Tcpip. . . . . . . : Activated
    The tunnel card isatap. {ADA5AF97-DFD7-4B63-9DDE-6E89D1933F1A}:
    Carrier status. . . . . . . . . . .: Media disconnected
    Description. . . . . . . . . . . . . . . : Microsoft ISATAP card
    Physical address. . . . . . . . . . : 00-00-00-00-00-00-00-E0
    DHCP enabled. . . . . . . . . . : No
    Tunnel card Teredo Tunneling Pseudo-Interface:
    Description. . . . . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    IPv6 address. . . . . . . . . . . . : 2001: 0: d94a: 4191: 4b7: 1148: 3f57: fafd (Prefe
    ated)
    The IPv6 address of the local connection. : fe80 :: 4b7: 1148: 3f57: fafd% 12 (Preferred)
    Deafult Gateway. . . . . . . . . . : ::
    NetBIOS via Tcpip. . . . . . . : Disabled
  • #10 16178819
    jimasek
    Help: 3783
    Rate: 2681
    I do not see a wireless card there !? Unless you threw the whole !?
  • #11 16178834
    bartekziom5
    I do not use a wireless card on a PC, I bought a router with a view to have Wi-Fi for mobile devices and laptops
  • #12 16178838
    jimasek
    Help: 3783
    Rate: 2681
    jimasek wrote:
    What does ipconfig / all show when you're connected to a wireless network - Link
    What did I ask about?
  • #13 16178856
    bartekziom5
    I can not connect to the router because it does not provide I'm surprised because when I connect the router via a laptop cable I can do a wireless network
  • #14 16178862
    jimasek
    Help: 3783
    Rate: 2681
    bartekziom5 wrote:
    l I can do a wireless network to my laptop
    I do not really understand this last sentence? If no device can see the SSID, it looks like a broken copy.
  • #15 16178866
    bartekziom5
    I mean, I can do it like a hotspot
  • #16 16178886
    jimasek
    Help: 3783
    Rate: 2681
    But do you have this network from Netis or from an AD-HOC laptop? I'm sorry but I do not know what you write to me now !?
  • #17 16178911
    bartekziom5
    With a laptop but it's a bit of a chore because the laptop must be turned on all the time to make the wireless network work
    Added after 6 [minutes]:
    Okay, less, I'm buying a new router thank you for closing time
The user is experiencing difficulties configuring a Netis WF2411 router for Wi-Fi connectivity with Multimedia Polska internet service. Initial troubleshooting steps included checking the router's configuration access and ensuring it was connected via the WAN port. Despite following the setup process, the user reported that neither the fast nor advanced configuration options were successful. Further investigation revealed that the router's wireless network was not visible to devices, leading to speculation about a potential manufacturing fault. The user ultimately decided to purchase a new router after failing to establish a reliable wireless connection.
