Unstable Backlight on LG 39LB5610 TV: LEDs Not the Issue, Voltage Fluctuations Noted
Ibuprom 6795 6
  • #1 16179494
    Ibuprom
    Help: 52
    Rate: 180
    The television has a strange condition. After about 30 minutes of work, the backlighting becomes unstable. It flickers, flashes, sometimes it turns off altogether. it happens a few-tens of seconds and the backlight is still working properly. The initial diagnosis - backlight wear - is rather wrong. Measurements of the strips showed 3 LEDs with a forward voltage of about 7V, the rest 6.6V at 300mA. 7V diodes were omitted for the test - but this did not solve the problem. No other signs of LED wear are visible - they all shine evenly, with no discoloration. Soldered connections, batten connections are additionally bridged.
    This TV is used, the BD9486F is not available from us. During the flickering, the supply voltage to the LEDs changes 170-230V. I omitted the MOSFET on the ground side, leaving the LED current measurement - it did not change anything. Measuring resistors replaced. I have managed to measure that during the unstable behavior of the power supply, the voltage varies on PIN1 BD9486F marked with UVO5.0. It varies around 4.5-6V. It seems that the instability of this voltage results from the damage to the BD itself, but as I mentioned - the system is difficult to access, the power supply itself is not cheap either. After the laminate, I do not see any other connection to this pin that could affect the level of this voltage. Can someone confirm whether this system can be the cause of the failure? Or maybe actually LEDs and I am looking unnecessarily?
    Motherboard LGP3942-14PL1
  • #2 16180456
    GanCegall
    Help: 339
    Rate: 1631
    On ebay from nearby Czech Republic EUR 19 with shipping, use the number that starts with "EAX ...."
  • #3 16180629
    Ibuprom
    Help: 52
    Rate: 180
    I found a CD for ~ 200 PLN with us. I just did not want to buy blind because there are no returns and the fault is unusual and ambiguous.
    But I guess I'll answer myself. Connecting the capacitor 220u to pin 1 of the BD stabilizes its operation. The backlight has stopped flickering and the TV has been working for several hours without any problems. So in this case, I will have to buy the CD, and in the future I will have to order a few spare BDs from Asian friends.
  • #4 16181754
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    e.g. Link_ LGP4750-13PL2 EAY62810801
    IC801 BD9486f
    IC101 SSC9527S
    IC601 R2A20133D
    Pin.1 BD9486f Link to nap. + 5V (out)> "made" from Backlight SW
    ps
    In Kiev, it costs about $ 6 / pcs * you have to wait sometimes (I don't know if they send to PL?)
    For example, in LG 42LB620V (matrix LC420DUE (FG)) there are
    - 4 strings (lines) 8 Led each, nap. power of the ruler is 49V
    * i.e. Led 6V
    On exit inv. (integrated into PSU> pcb: EAX65423701 (1.9)) is 196V (205) / 250 mA
  • #5 16181935
    Ibuprom
    Help: 52
    Rate: 180
    It was this scheme that I used to diagnose this fault.
    Additional question - for the future. I mentioned the diode conduction voltage. 3 pcs had 7V, the rest 6.6 - at 300mA. Do these 3 items end their lives or can it be blamed on the production spread? As I mentioned - they glow the same as the others and you can't see anything happening to them. Cold diodes have a slightly different operating voltage (for these 3 diodes - 7.5V, the remaining 7V), but after a few seconds their voltage stabilizes at the previously mentioned level.
  • #6 16183575
    Indyczes
    Help: 186
    Rate: 272
    Leave the LEDs alone.
    Greetings
  • #7 16183594
    Ibuprom
    Help: 52
    Rate: 180
    Ok. Thank you for all your comments. greetings
The discussion revolves around an LG 39LB5610 TV experiencing unstable backlighting after approximately 30 minutes of operation, characterized by flickering and occasional complete shutdown. Initial assessments ruled out LED wear, as measurements indicated consistent forward voltages across the LED strips. The user noted voltage fluctuations between 170-230V during flickering, and attempts to isolate the issue included bypassing components and replacing resistors. A breakthrough occurred when a 220uF capacitor was connected to pin 1 of the BD9486F IC, stabilizing the backlight and resolving the flickering issue. The user plans to purchase the BD9486F for future repairs and seeks clarification on the significance of the differing forward voltages of the LEDs.
