Peugeot 407 2005: Uneven Heating - Cold Air on Right Side, Ventilation & Airflow Regulation
yakubuuu 9354 4
  • #1 16179597
    yakubuuu
    Hello. I have a problem with ventilation in Peugeot 407 2005. Well, the left side works well and the right is still cold air. The airflow regulation works correctly. Please help.
  • #2 16179943
  • #3 16180950
    yakubuuu
    And can I go for some time like this because now it is fragile with money ... can something happen if it does not work?
  • #4 16181025
  • #5 16181601
    kotweiler
    Help: 18
    Rate: 74
    Enter in Google "Damaged temperature control flaps Peugeot 407" you will learn how to check if the flap is not damaged, broken, In this model it is a very common fault. The flap does not rotate because the axle is broken. You can ride without fear that something will happen.
