Manta SVR201HD IP camera - Preview on a PC
jakub.waw 7806 7
  • #1 16181678
    jakub.waw
    Good morning
    The IP camera connects to the network, shows the live image in the iOS application. I can't search for this camera in any PC camera program.
    Each program asks for a URL, but for no treasures I can't get to the right one.
    I am asking for help, preferably in iSpy :)
    Thank you greetings.
  • #2 16181824
    genuine486
    Help: 20
    Rate: 59
    If you have access, check the list of DHCP clients on the router. The camera should have its own IP, which you then enter as the address.
  • #3 16182424
    jakub.waw
    I know the IP address, the problem is that every program on the camera to use the cameras asks for the URL, giving the IP even with the port does not give a picture.
  • #4 16184547
    genuine486
    Help: 20
    Rate: 59
    it may be a computer problem. the streamed image can use codecs, quicktime, flash plugin etc. make sure you have everything
  • #5 16185681
    likufanele
    Help: 16
    Rate: 10
    What programs did you try on?
  • #6 16361059
    gkwiatkowski
    CCTV and Stationary Alarms specialist
    Help: 649
    Rate: 1225
    jakub.waw wrote:
    Good morning
    Can you give an example of how the image from this camera looks like day and night?
    Best regards,
  • #7 17120901
    poho
    Rate: 9
    You take Add -> IP Camera -> third tab -> in the URL you paste:
    rtsp://{IP_KAMERY}/ch0_0.h264
    You click Test and it should bubble :)
  • #8 17392027
    edekk
    Help: 93
    Rate: 115
    Just install the VLC media player and paste in File> Open network stream>
    this line rtsp: // user: password @ ipaddress: 554 / ch0_0.h264, this is how it looks rtsp: // admin: admin(_at_)192.168.2.128: 554 / ch0_0.h264.
    You can connect to the camera with any browser, but I got the image only on Internet Explorer. On others it is possible to configure, however, despite installing the OCX plugin, it still asks for it and the image is missing. On Android within the network or LTE only P4PCamLive works, but there is no full camera configuration .The camera also works on the nBox tuner with the rtsp plugin installed and connected to the net. Another camera works with me outside my network on the domain and rtsp. I haven't tested this yet, so that the image is on the computer and the camera should be in a different place.
✨ The discussion revolves around the Manta SVR201HD IP camera, specifically issues related to accessing its live feed on a PC. The user successfully connects the camera to the network and views the live image via an iOS application but struggles to find the correct URL for PC camera programs. Responses suggest checking the DHCP client list for the camera's IP address, ensuring necessary codecs are installed, and using specific URL formats for streaming. Recommendations include using VLC media player with the RTSP protocol and configuring the camera through Internet Explorer, as other browsers may require additional plugins.
