Choosing the Right Converter and Antenna for Cyfrowy Polsat: Single vs Twin, 90 cm Dish
lori22 5430 3
  • #1 16463308
    lori22
    Hello, on days I will be a happy owner of Polsat Cyfrowy. I buy the satellite dish myself, probably aluminum 90 cm.
    I have a problem with the converter, I would like to receive two satellites so I think that the multiblock converter remains the question of whether twin or single?
    And what I want to achieve - connect two TVs to the decoder and that the channels do not duplicate, so that the same thing does not fly on two receivers, is it possible? Teee my dreams;>
    To tell you the truth, I don't understand if I need a single or twin converter,
    thanks in advance.
    simhak
    Help: 109
    Rate: 336
    Monoblock or monoblock Twin.
    One decoder - one TV set.
    Need more set-top boxes?
    Take a multiroom.
  • #3 16463383
    lori22
    I understand more or less but in the future if I wanted to connect a decoder to the other TV in some way, then without multiroom there is no option?
    I also mean costs.
    sanfran
    Help: 961
    Rate: 3001
    It is possible, but it will be the same on both TVs. If you want to have different programs, only a second decoder and a multi-room.
