Asus R556L: No Sound on Windows 10 64bit - How to Install Realtek Sound Card & Fix Audio Issues
GrandBB 7329 7
  • #1 16186276
    GrandBB
    I can't install sound for Windows 10 64bit. The hard disk was replaced in the lap. After all, the equipment was twisted and the system was installed. The only problem is the lack of sound. Does not recognize the sound card. In this clap, the Realtek system is located on a separate board, which is connected to the motherboard, a hard disk to it and, after the ribbon, another board with a USB port, SD card slot and jack.
    Any ideas?
    Asus R556L: No Sound on Windows 10 64bit - How to Install Realtek Sound Card & Fix Audio Issues Asus R556L: No Sound on Windows 10 64bit - How to Install Realtek Sound Card & Fix Audio Issues
  • #2 16186393
    Szymek1989
    First thing, download everest portable and see if it detects the card, if not the best way is windows live or linux and check if there is sound and exclude a hardware fault, and confirm that this is the fault of the system.
  • #4 16186542
    GrandBB
    Link sound driver installed. Windows continues to shout that the audio output device is missing. In Everest, it prepares HD Audio controller for PCI / PnP and nothing else.
  • #5 16186551
    Szymek1989
    Open Settings - Update and security - Run Windows Update (Realtek sound driver, download and install), maybe the card was damaged during disk replacement, see in the bios if the card is visible
  • #6 16186620
    GrandBB
    The pictures show both boards and the Realtek system for sound. I don't see any physical damage at first glance. Now I tried to run it in a spider. The system boots but no information about hardware detection / installation appears.
    Added after 48 [minutes]:
    In general there is some ride with this laptop.
    Model on the sticker: R556LJ
    Model printed on the motherboard: X555LD
    Model that is visible in DxDiag: X555LJ
    And be smart here? ;)
  • #7 16186905
    Szymek1989
    it is best to take a different disk and install win 7 on it and everything will be explained, but from what you write it looks like it is damage to the hardware and not the fault of the software
  • #8 16186986
    GrandBB
    The disk connector is damaged. He reads it once and not once. The problem is that I have trouble finding this tile. I don't want to order from China.
The discussion revolves around resolving audio issues on an Asus R556L laptop running Windows 10 64-bit after a hard disk replacement. The user reports that the sound card is not recognized, and despite installing the Realtek audio driver, Windows indicates that the audio output device is missing. Suggestions include using Everest to check hardware detection, running Windows Update for driver installation, and verifying BIOS settings for the sound card. The user suspects potential hardware damage, particularly to the disk connector, complicating the troubleshooting process. The model numbers mentioned include R556LJ and X555LD, indicating possible discrepancies in identification.
