Volkswagen 1.9Tdi - Can I convert the turbine in 1.9Tdi to a compressor?
JacekW.1982 11124 8
  • #1 16187759
    JacekW.1982
    Is it possible to replace a turbine in any diesel with a compressor, e.g. from an old merca? How would this affect performance?
  • #2 16187790
    bart1500
    Help: 12
    Rate: 66
    After all, this will increase the cost of the car. Better chip for better performance
  • #3 16187801
    JacekW.1982
    Let's assume that it pays off, how would it affect the performance and operation of the engine (assuming a new map is loaded)?
  • #4 16187809
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    The advantage of a turbocharger is a large increase in power, but it is felt only when the compressor reaches its proper speed. The time that passes from the moment the gas pedal is depressed until the compressor is fully accelerated is called the turbo lag.
    In the case of a compressor, there is no turbo hole. On the other hand, the increase in power is smaller, but it occurs linearly from the moment the car starts moving, because the compressor is driven by the crankshaft. Such a solution, i.e. the constant coupling of the compressor with the engine, causes, however, that the engine consumes more fuel than the one equipped with a turbo.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #5 16188757
    JacekW.1982
    Okay, but suppose I am a partisan Janusz and I do something like the picture below. The principle of operation is similar to running in a scooter. When I need it, I have maximum top-up from low revs all the time, and if not, I don't care much. Besides, when the turbocharger collapses, the exhaust gas probably has an easier exit route, right? I guess it gives power too? And from this shaft probably a lot of this power such a compressor does not pull. Volkswagen 1.9Tdi - Can I convert the turbine in 1.9Tdi to a compressor?
  • #6 16188851
  • #7 16189344
    JacekW.1982
    Look at the picture that says computer controlled. Besides, if facilitating the exit path for exhaust gases does not give any effects, why after changing the exhaust, such a Vtec can spit more out even with 15KM? Turbo must also get energy from somewhere to create pressure? There is nothing for free.
  • #8 16189406
  • #9 16189530
    nici
    Help: 266
    Rate: 979
    I'm curious about this program and the computer that would control it
The discussion revolves around the feasibility of replacing a turbine in a Volkswagen 1.9Tdi diesel engine with a compressor, specifically from an older Mercedes model. Participants highlight that while a turbocharger significantly boosts power, it suffers from turbo lag, whereas a compressor provides a more linear power increase from low revs but consumes more fuel due to its direct connection to the crankshaft. The conversation also touches on the potential performance implications, such as increased fuel consumption and the need for a new engine map. Some contributors question the practicality and efficiency of such a conversion, suggesting that it may not yield significant benefits compared to traditional turbocharging. The idea of using a compressor alongside a turbocharger is mentioned as a niche solution, with examples of extreme modifications leading to performance issues.
