Dacia Dokker vs. Fiat Doblo 1.4 Gasoline: Comparing 1.6 Petrol, Failure Rate, Corrosion & More
LupekT 6507 5
  • #1 16195825
    LupekT
    Dacia Dokker or Fiat Doblo. What to buy, I wanted Doblo 1.4 gasoline. Colleagues urge Dokker 1.6 petrol, what this Dokker, what failure rate, burning, corrosion, finish, can buy with gas installation. I will add that I mean a passenger car, not a delivery truck. I am tempted by the lower price. Please advice.
  • #2 16195867
    leon99
    Level 19  
    Help: 18
    Rate: 103
    Dacia it completely fell. take Fiat, the failure rate is 5 times lower
  • #3 16215529
    Eidems
    Help: 83
    Rate: 253
    Apparently, Dacia is not an agreement, also speak to Fiat ;)
  • #4 16215562
    Aleksander_01
    Help: 1167
    Rate: 3435
    I did these dockers a few times, breakdowns like breakdowns, but the prices of spare parts on the site (you will not buy anywhere else) are already space. Example - direction indicator and light switch - price 680 PLN. Forget that something from renews will come up, completely different plugs and dimensions. I would take Fiat.
  • #5 16215598
    kkknc
    Help: 1915
    Rate: 6709
    I have two rides, I do not whimper. They are two years old, one 60,000, the second 94,000. Noisy cars, mainly from the rear, you can hear the exhaust and the suspension. Performance poor. But driving cheap on gas. Prices for typical parts are low. The shifter is from Valeo cheaper. It can be fixed as I can see. Matching the interior and somehow the artists cries out to heaven for vengeance. The 1.6 engine is out of the question ..... Even the EGR is gone. Simple as building a flail. Only the crankshaft position sensor, MAP sensor. And a temperature sensor. Probes, of course. There is nothing to break. Traditionally regulated valves. A lot of space under the hood. The interior is also large. Previously, I had an MCV that was very durable. You can deal with electrics and plugs.
    Fiat has disadvantages too. But it is quieter and has better interior interior. It is nicer to sit. More problems with electrics.
  • #6 16741582
    sccoty
    Rate: 16
    I have a docker 1.6 106 thousand at the very beginning I had a problem with the orchard later peace of mind only the light lever 1 time under warranty they replaced 2 g and once repaired by an electrician by installing relays auto smiga weak patches price to quality adequate
