Installing SDR Receiver Software on Dell Laptop with Windows 7 32-bit: Zadig Compatibility Issues
aktywny27 11727 7
  • #1 16197385
    aktywny27
    Rate: 12
    I can't install the SDR receiver software on a Dell laptop and under Windows 7 32-bit. I started Zadig and set compatibility to Windows 7 and nothing and tried on newer versions of Zadig and nothing. Please help. Below is a screen with an error.
    • Installing SDR Receiver Software on Dell Laptop with Windows 7 32-bit: Zadig Compatibility Issues sdr.jpg (355.11 KB) You must be logged in to download this attachment.
  • #3 16198288
    aktywny27
    Rate: 12
    And there is written in this topic about the antenna amplifier and whether it is worth investing in such a device. And I have the antenna so-called Radmor stick and what will change then and where to mount it and which one. Because I also heard about the inverter and also what to buy and how to mount and what will be better then. Please help
    Added after 1 [hours] 32 [minutes]:
    I can't install
  • #4 16198662
    yes2mike
    Help: 258
    Rate: 322
    First of all, you MUST click "install-rtlsdr" in the SDRsharp directory.
    You don't need an amplifier. He is in the sofas and is doing quite well.
  • #5 16209480
    aktywny27
    Rate: 12
    And how to install debian tails in linux. Please help
  • #6 16312223
    Hajna
    Help: 69
    Rate: 145
    Under win7 try this ready. The zodiac is in the catalog.
    • sdrsharp13.rar (6.84 MB) You must be logged in to download this attachment.
  • #7 16318344
    aktywny27
    Rate: 12
    I have already installed sdrsharp 14 and it works and the topic can be closed.
The discussion revolves around issues faced while installing SDR receiver software on a Dell laptop running Windows 7 32-bit, specifically related to compatibility with Zadig. Users suggest following a specific installation guide and emphasize the importance of clicking "install-rtlsdr" in the SDRsharp directory. Some users mention that an antenna amplifier is unnecessary for basic setups. The original poster later confirms successful installation of SDRsharp 14, indicating resolution of the initial problem.
