Volvo XC60 D3 AWD Kinetic 2011: Airbag Replacement Set Inquiry for Front Cushions at 163,000 km
kornias 17370 15
What parts and programming are needed to repair deployed front airbags in a 2011 Volvo XC60, and is buying an airbag set enough?
No, the airbag set by itself is usually not enough; you may also need the airbag sensor/module and, at minimum, the seatbelt tensioner and belt buckle/fastener replaced after the crash [#16206434] [#16207022] After installation, the crash data must be cleared or the airbag controller must be replaced with one having the same numbers, or a new controller bought [#16206452] In this Volvo, component protection and online programming may also be involved, so a simple fault erase is not always possible [#16206554] Several replies stress that without reading the car first you cannot know whether the module can be cleaned or must be replaced, so diagnostics come before buying parts [#16207022] Overall, the thread suggests the repair can get expensive and the car may not be a good buy unless you fully calculate the remaining costs [#16206434] [#16207022]
  • #1 16206400
    kornias
    Rate: 45
    I am interested in buying VOLVO XC60 D3 AWD Kinetic
    163,000 km
    05/2011
    120 kW (163 PK)
    Diesel (Roetfilter)
    Price: 10,000 euros except that the accident was repaired in front of the front cushions (the driver and passenger the rest is OK) so I would have to replace them myself here where I live.
    I found such a set with allegro link
    The question is whether all that I need to replace in the airbag system is included in this auction?
    Just erase the error of the blown up pillows or an exchange computer?
    It pays to buy this car ??
    I did a lot of things but I never had the opportunity to exchange pillows for my question.
    Volvo XC60 D3 AWD Kinetic 2011: Airbag Replacement Set Inquiry for Front Cushions at 163,000 km Volvo XC60 D3 AWD Kinetic 2011: Airbag Replacement Set Inquiry for Front Cushions at 163,000 km Adds a photo.
  • #2 16206434
    coperfild
    Help: 291
    Rate: 1697
    You still need to buy or repair a sensor air bag. I do not recommend that I would be afraid to ride it, besides I saw a few remanufactured planks for me, the cesspool after 2.3 years looks like roofing felt.
    Matylda_26
    Help: 6
    Rate: 45
    By some miracle, there are many post-accident improvements and they look like new.
    It is better to buy a car after a collision where the pillows were shot than after an accident made for a dealer where instead of pillows there are resistors.
    As for the set it is enough. Then you will have to delete the crashdata or replace the driver with a different one with the same numbers from a heavyweight car or buy a new airbag driver.
  • #4 16206467
    andrzej20001
    Help: 1578
    Rate: 6670
    Ooo regeneration boards with 500-600 plus sensor and resistor. You'd better make a board to buy your seatbelt straps and make yourself yourself, and you know what you have. And if it pays off, you have to convert it yourself. There will be fees, transport, parts, painting, first service and some of 20 other craps.
  • #5 16206475
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    But not in this volvo model you do not exchange any component without a visit to the site.
    Also, either to repair the sensor or to accept the lack of airbag and information.
    You can make a board and get somebody embracing airbags but you have to take into account that 2000-3000 PLN is definitely not enough.
  • #6 16206476
    Matylda_26
    Help: 6
    Rate: 45
    Why is that? Is it about diagnostic equipment?
  • #7 16206480
    Help: 1405
    Rate: 6430
    In general, you once had volvo from these years, do you know what it involves?
  • #8 16206516
    Matylda_26
    Help: 6
    Rate: 45
    I have a BMW X6. I asked a question that I can see that you can not answer.
  • #9 16206554
    andrzej20001
    Help: 1578
    Rate: 6670
    Component protection and online programming
  • #10 16206947
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Forgive this set unless you want to be cheap and just be.
    I know how such boards look later and how they behave during an accident.
    Sellers assure that like a factory and the pillow comes out at the bottom or side because it can not tear the board, you can still get a putty knife.
    For that it would be safer and not the other way around. It's better to buy a used set.
  • #11 16207022
    vollvek
    Help: 10
    Rate: 99
    Link to the auction does not work. In addition to the cushions you have to replace at least the belt tensioner and driver belt fastener, but the replacement belts can be much more. Without reading the car, the computer can not be determined whether the pillow module will be replaced (or the crash can be cleaned) or just delete the codes. As for profitability, you have to count. Have you seen the repaired front from the inside and from the bottom? because there can be black pudding. Buying a broken car has pros and cons.
  • #12 16207069
    coperfild
    Help: 291
    Rate: 1697
    Come on, it's not the old VW that you erase the cable.
  • #13 16207384
    kornias
    Rate: 45
    Thanks for all the information.
    for deleting the craschdata from 150zl to 250zl
    fees in pl, transport, varnishing, the car drops out in Luxembourg and I would like to put it together here
  • #14 16207636
    vollvek
    Help: 10
    Rate: 99
    Currently, in the era of "Chinese" even ordinary users have Vide. It is not the time that no one could even delete codes in pillows outside the ATS.
  • #15 16207892
    Help: 1405
    Rate: 6430
    You do not erase the vida, well, what are you? Only the programmer, and I do not know what is sitting in this helm.
  • #16 16208072
    vollvek
    Help: 10
    Rate: 99
    It depends on the driver, in some you can delete the crash Vida for example XC60 2013 or 14 you can, but I had only in mind just clearing the codes in the pillows.
The discussion revolves around the inquiry about replacing the airbag system in a 2011 Volvo XC60 D3 AWD Kinetic after an accident that deployed the front airbags. The user seeks advice on whether a specific airbag replacement set found online includes all necessary components to restore the airbag functionality, including the airbag control unit. Responses indicate that in addition to the airbags, the seatbelt tensioners and possibly the airbag control module may also need replacement. There are concerns about the reliability of aftermarket parts and the importance of proper diagnostics to ensure safety. Users emphasize the need for professional assistance in clearing crash data and programming the airbag system, as well as the potential costs involved in repairs and parts replacement.
