Passat B5 2002: Shock Sensor Location & Airbag Cushion Replacement Process
NaptaPL 15096 4
  • #1 17206320
    NaptaPL
    I had a collision Passat B5 FL 2002, shot driver and passenger cushions.
    Therefore, I have the following questions - is it enough to put on new cushions and clear the error or is it necessary to replace the shock sensor?
    Where is this sensor located?
    DexonX
    As for the sensor, it is rather new with Allegro.
    And the location:
  • #3 17206417
    NaptaPL
    Thank you very much, I do not know why it did not occur to me to googling in English :)
    edit:
    I am still wondering how to check if belt tensioners have shot off?
  • #4 17206433
    DexonX
    It seems to me that after the activation of the tensioners they are locked.
  • #5 17206717
    milejow
    Help: 1563
    Rate: 5148
    NaptaPL wrote:
    How to check if belt tensioners have shot?
    How the cushions worked, the tensioners all the more.
    Działalność własna
    Mętów 99, Lublin, 20-388
