Smart PSS Compatibility: Connecting XrPlus & Non-Dahua Recorders Remotely
zbychu6 6072 6
  • #1 16207027
    zbychu6
    Hello. Has anyone set up remote connections by SmartPss with recorders, e.g. XrPlus or other brands than Dahua ?? It works??
  • #2 16208975
    zbychu6
    Has anyone managed to do remote viewing with XM devices (xiongmaitech) on the Dahua software (any manager) ??
  • #3 16212124
    jpl
    Help: 240
    Rate: 223
    No and it will not work, it does not work like this that You will buy the cheapest and worst crap, you will also steal a soft from a decent supplier and you will connect it all ...
    SmartPSS compatibility limited to Dahua-based AHD recorders
    #4 16212400
    Rob888
    Help: 34
    Rate: 28
    The 4-channel AHD bessky costs as much as $ 30 or as much as PLN 130 :D
    I tried SmartPSS does not connect to recorders from other manufacturers.
    AHD supports but only its own Chinese producer Dahua (distributor in Poland - BCS)
    https://www.sklep-bcs.pl/re regatory_dvr
    http://www.dahuasecurity.com/
    If you have different analog recorder systems, for example with CMS:
    http://janexint.com.pl/index.php?id_product=2473&controller=product
    you will have a common image (the program adds devices from the following manufacturers
    H264DVR (maybe BESSKY)
    Hikvision
    Dahua
    Huang He
    When it comes to AHD recorders:
    Distributor in Poland XrPlus
    http://xrplus.pl/index.php?action=kategoria&idKAT=3
    i.e. Chinese BESSKY:
    http://www.bessky.com/product/class/164/
    (Factory in Guangdong, China (Mainland) - Industrial grade embedded micro controller chip Huawei HIS chipset Hi3531
    DVR probably assembled in Korea)
    So far I have not seen a program that would "fasten"
    all AHD recorders from different manufacturers
    For example, Dahua (BSC) for AHD has Smart PSS or BCS VIEW
    BCS WIEW sees and enables remote access to Novus recorders
    and vice versa NHDR 5000 Viewer Novus sees enables remote access to the BCS AHD recorder
    The remaining AHD compartments have a VMS incompatible with other recorders.
    I don't know if the new CMS from XrPlus- BESSKY will see any other recorders, but I'm curious.
    Let us remember colleagues that Poland is only a neocolony without NO producers
    recorders. Only smart sellers operate in Poland, who sell Chinese registrars under other names invented by sellers in order to earn from customers who do not buy directly from the PRC
  • XM recorders are comparable to Chinese Dahua units
    #5 16212495
    zbychu6
    Buddy, I don't know how long you deal with this topic, maybe you remember what was said about BCS when it conquered the Polish market ... I do not agree with the opinions about cheap crap, XM recorders do not differ much from the similarly Chinese Dahua. They have been working continuously for several years. Some surreptitious advertising ...
    As for the answer to the "management" issue of different recorder systems, it was not a substantive answer.
    Hikvision
    Dahua
    Huang He
    Rob888 thank you for the substantive answer.
    It's good that at least the AHD cameras from XM work on Dahua and vice versa :)
  • #6 16213889
    jpl
    Help: 240
    Rate: 223
    I have been working in CCTV for over 14 years and I have full contact with all CCTV factories in the world, so I have a very good idea of what and how it is done.
    I still remember recorders on wavelet and JPEG2000 ;-)
    And BCS - at the beginning it was AVTech, then DAHUA - and it was said badly because at the beginning it was poor equipment, e.g. recording like 2 D1 channels and the rest of CIF, or playing max 2 channels.
    Are you saying that the recorders that trigger DDOS attacks around the world (XM JUFENG) that are not in any way protected against intrusion - are good recorders? hmmm
    I would not even admit that such equipment is installed.
    As for the software - think about something like a license - usually "free" software attached to some hardware has license provisions that clearly state that their use is allowed and free only when buying a device, e.g. EVOS.
    Gentlemen - we install legal programs by definition, because then there are checks and there is panic and crying.
    Advising on installing programs that may later create legal problems - I would pass.
    Because they are recorders from the same manufacturer - you can also find the same under the DVRMX brand in Poland
    You're right, and the paper will accept everything - so then we have crap.
  • #7 16214815
    treborsz
    Industrial cameras specialist
    Help: 124
    Rate: 240
    Summarizing:
    - we buy ourselves in China - thanks to this, we will get better trading conditions, and this additionally with excellent technical support and unmatched warranty conditions;
    - buying on our own, we have 100% confidence that the device (or maybe the entire purchased batch of devices) will work or work with our expectations - cleverness will free us from crap;
    - buying directly in China, we will be more clever than smart sellers, paper in China is real, and what the producers from this region say about the parameters of their devices is a revealed truth.
    Amen.
The discussion centers around the compatibility of Smart PSS software with various recorders, specifically the XrPlus and other non-Dahua brands. Users report that Smart PSS does not support remote connections with recorders from manufacturers other than Dahua, such as XM devices (Xiongmaitech) and Bessky. Some participants argue that while cheaper brands may not be as reliable, they can function adequately with Dahua systems. The conversation also touches on the importance of purchasing equipment directly from manufacturers in China for better support and warranty conditions. Concerns are raised about the security of certain recorders, particularly those associated with DDOS attacks. Overall, the consensus is that Smart PSS is limited to Dahua devices for remote viewing.
