Pralka Bosh WFR 2841: Wasserhahn Zu? Message Appearing Multiple Times During Wash Cycle
Piotrhb 7083 6
  • #1 16209074
    Piotrhb
    Hello all.
    I registered on this forum as I hope someone will help me. Well, my washing machine displays the message "wasserhahn zu?" After pressing the "start" button. You can press start or wait and the message disappears by itself.
    During washing, the same message pops up 7-9 times, but at the same time the washing machine stops and the drum lock is turned off. Just like pressing Pauze. Then I have to press start and the washing machine starts. Later, another message, start and another, etc. The washing is done, the washing machine is washing, but these strange messages pop up and you have to check every now and then if it pops up sometimes and whether you need to press start. It is very tedious.
    I have no idea what this may be ... For peasant reason it is probably not a mechanical fault because then the washing machine would not wash? I do not know. Therefore, I am asking for help. Maybe someone had a similar problem or knows how to solve it.
    best regards
    tod.1977
    Help: 65
    Rate: 150
    Hello. Maybe there is a problem with the water supply to the washing machine.
    dzi_dziuś
    Home appliances specialist
    Help: 341
    Rate: 1170
    The washing machine asks for a wasserhahn, then check this wasserhahn - tap :) .
    For starters: https://www.youtube.com/watch?v=4JXuZBtFqps, nicely shown, no language needed.
  • #4 16209901
    Piotrhb
    As for the water supply, that's ok. But this video is cool, but I don't understand what that guy did there. Was there something clogged in the inlet? Forgive me if I ask for things that are obvious to you :)
    tod.1977
    Help: 65
    Rate: 150
    Open my friend the powder drawer like the German in the video and see if the stream in the dispenser is strong or if the water is barely dripping. It seems to me that this gentleman was cleaning the strainer in the solenoid valve. Let a colleague check and it will be clear. Best regards.
  • #6 16211184
    Piotrhb
    Many thanks to colleagues for the answers. Tomorrow I'll have time and I'll do it. I think you may be right, because yesterday I opened the drawer and saw that there was a lot of old washing powder in the right compartment. My wife said that due to the fact that she did not take the powder, she started using capsules .... I do not push myself to wash and my wife did not complain ... Well, tomorrow I will try to do something. I will describe what will come of it. best regards
  • #7 16220815
    Piotrhb
    Thank you very much for the advice, because everything works great. Indeed the strainers were dirty. One at the aquastop, the other at the "inlet" to the washing machine. It's amazing that it was such nonsense and we got so tired. Thank you very much again and best regards!
The user reported an issue with their Bosch WFR 2841 washing machine displaying the message "wasserhahn zu?" multiple times during the wash cycle, causing interruptions. Responses suggested checking the water supply and the inlet for clogs. The user confirmed that the water supply was fine but noted old detergent buildup in the drawer. After cleaning the strainers at the aquastop and the inlet, the washing machine functioned properly, resolving the issue.
