ARRIS TG862S Modem Configuration Issues with Vectra: Blocked Gaming Ports
bodek98 10338 12
How can I open blocked gaming ports on a Vectra ARRIS TG862S modem when I cannot access its configuration panel?
You can usually open the ports yourself by logging into the hidden admin account at http://192.168.0.1/ and then creating the needed port redirects [#16278622][#16273351] For this Vectra modem, the login uses the admin account and the daily generated password, and one user noted that case sensitivity matters and that it worked over Wi‑Fi [#16279117] If the password does not work while the coax cable is connected, disconnect the coax, hold the reset button for about 15 seconds, wait 2–3 minutes for the modem to boot, connect to Wi‑Fi, and try the admin login again [#16279182] If you still cannot get in, the fallback is to ask Vectra via EBOK or the hotline to switch the modem to bridge mode, but then it no longer works as a router [#16278622][#16271861]
  • #1 16253300
    bodek98
    Rate: 25
    Hello, I have a problem with blocked ports, I have Internet in "Vectra", after changing the contract to a better internet I got a Wi-Fi modem, but now I do not have access to the modem configuration.
    The biggest problem is with games that use their ports, for example, you can hardly play Heroes 3 with your buddies online (e.g. via Game-ranger "), just like The crew and many other games, in general, in my opinion, ports should be completely unlocked, or at least you should have access to do it yourself. I once heard that when you call the operator and ask you to unblock ports, they switch the modem to the "bridge" mode so it doesn't work as a router (only the modem remains) , which of course does not suit me. The question is if there is any way to unblock these ports and do they actually do such things after such requests? Thanks for all the information and help! ;)
    I have Windows 7 Ultimate 64 bit
  • #3 16271861
    bodek98
    Rate: 25
    So as I thought, unfortunately you will have to switch to bridge mode: /. If this is the only way out then the topic is close, thanks for the hint ;)
  • #5 16278550
    bodek98
    Rate: 25
    Is this legal? The point is that there would be no immediate action, that I would log in to the admin account illegally and change something ...
    edit:
    Okay, I tried to log in by all means, it doesn't work, from what I read in the comments they also wrote that it worked for a long time, but not anymore. Any other tips?
  • #6 16278622
  • #7 16279101
    bodek98
    Rate: 25
    What I mean is that the password does not work on this page "password of the day",
    user name, enter "admin"
    password from the site (today's) in this case "NUD21IF1MV"
    I reset the modem with the button on the back and still the same, when the unplugged coaxial cable also had an incorrect password.
    Is it possible that I'm doing something wrong or doesn't it actually work anymore? Or maybe they changed something in my modem and set a permanent password?
  • #8 16279117
  • #9 16279125
    bodek98
    Rate: 25
    I connect via LAN - I have a desktop computer, I can try on the phone, I enter the data rather well
    From what I know, I do not have any login and password given on the back, in addition, it seems to me that once I asked them about this data, they said that they could not provide it.
  • #10 16279133
  • #11 16279153
    bodek98
    Rate: 25
    By phone the same, with the login and password on the back, you probably need a wifi password, if so I am connected by phone, I go into the browser and do the same as on a PC - the same answer.
  • #12 16279182
  • #13 16279216
    bodek98
    Rate: 25
    But wifi works normally on my phone, I have internet, applications work, it does not work only logging in to the browser to the modem settings via http://192.168.0.1/ with this generated password, I do not know what's going on anymore mixed up: /
The discussion revolves around issues with the ARRIS TG862S modem configuration when used with Vectra internet service, specifically regarding blocked gaming ports. The user is unable to access the modem's settings to unblock ports necessary for online gaming, such as Heroes 3 and The Crew. Suggestions include switching the modem to bridge mode, which disables routing capabilities, and attempting to log in to the modem's admin interface using default credentials. However, the user faces difficulties logging in, even after resetting the modem and trying various methods. Other participants mention that Vectra imposes restrictions on modem configurations, complicating the process of port redirection. The conversation highlights the challenges of accessing modem settings and the potential need for contacting the ISP for assistance.
