Opel Astra G 2.0 DTI 2001: Electric & Hydraulic Support Oil Recommendations - ATF4 Mobil Possible?
ziooober88 15927 4
  • #1 16230459
    ziooober88
    Rate: 491
    Hello, I have Opel Astra G 2.0 DTI 2001. I have regenerated the mangle and now I have to pour the oil over. The support is electric and hydraulic. What oil should I pour in there? Can it be ATF4 mobila? Or maybe something else you recommend?
  • #2 16230545
    GRZECHU111
    Rate: 20
    If Mobil to Mobilube 1 SHC, it can be Castrol CHF, although ATF4 should also do it, but with these moulders it's better not to experiment
  • #3 16230890
    ziooober88
    Rate: 491
    I still have atf 220. The guy I used to make the maglevers told me to flood the green. So what is best to buy now and how many things going on there?
  • #4 16232780
    GRZECHU111
    Rate: 20
    then buy a febi FE06161 good and when it comes cheaply about 0,7l
  • #5 16264405
    ziooober88
    Rate: 491
    Hello, I bought the green FEBI oil. So far support is quiet and you do not hear it at all.
