Installing Odis from AliExpress: Resolving Error ODS9007E & Failed/Interrupted Update
ren.lag.01 25425 9
How do I fix the ODS9007E "Infrastructure. Online connection VW. Mirror2: Update has failed or has been interrupted" error that appears at the end of an ODIS installation/update?
ODS9007E during the final ODIS update likely means there is a problem with the postsetup database rather than the basic installation itself [#16231848] Java was already installed in the reported case, and the usual workarounds tried there—moving the ISO to C:\, changing the system date to March 2016, and running ODIS as administrator—did not help [#16231726] The suggested fix was to get a working postsetup database from a known-good ODIS installation [#16231848] The thread does not provide a complete repair procedure, only that the database is the likely culprit and the user would need a working copy of it [#16233237]
  • #1 16231310
    ren.lag.01
    Rate: 15
    Finally ODIS arrived from aliexpress.
    Unfortunately, during the installation, at the very end of the process, I get an error "ods9007e"
    exact command:
    ODS9007E Infrastructure. Online connection VW. Mirror2: Update has failed or has been interrupted.
    I have browsed the internet and there is some information on what to do about it.
    It seems to me that I have tried all the things and still the error pops up ...
    Has anyone dealt with this?
    I will be very grateful for any help ;)
  • #2 16231480
    szymitsu21
    Help: 343
    Rate: 1302
    Write to yellow, a good seller will help you.
    I know that some even install by TW.
  • #3 16231481
    nici
    Help: 266
    Rate: 983
    Write step by step what you are doing, and I will tell you where you are making the mistake.
  • #4 16231726
    ren.lag.01
    Rate: 15
    ok, so it seems to me that everything is in accordance with the instructions from the album.
    1. I have never had any ODISA installed, VAS so I do not have to uninstall the old software.
    2. I click on Instal.exe from the Setup directory. The program installs on drive D in the programs directory.
    3. During the installation, I give the license.deg track
    4. The program installs successfully, after which I replace the OffboardDiagLauncher.exe file with the second one indicated in the manual.
    5. Mount the iso file in the virtual drive.
    6. I fire ODIS and point to the path to the update file
    I give you the username and password ABC and ABC as in the instructions.
    7. At the end of the update installation, an error pops up about which I wrote
    now a few tips that I found on the Internet in various Anglo, Russian-language forums
    - transfer the iso file to the C: drive so that the path is C: postsetup \ update - it did not help
    - withdraw the date in the comp to March 2016 (I know funny but such thing was suggested by the Russians) - it did not help
    - run ODIS as an administrator - it did not help
    I'm in dead end...
  • #5 16231848
    nici
    Help: 266
    Rate: 983
    It looks like you have a problem with the postsetup database.
    Java installed?
  • #6 16233200
    ren.lag.01
    Rate: 15
    any idea where to get a postsetup base?
    Yes, java installed
  • #7 16233237
    nici
    Help: 266
    Rate: 983
    From someone who works. :) I had somewhere.
  • #8 16233313
    ren.lag.01
    Rate: 15
    will you look? :D
    for now, I'm looking at torrents ...
  • #9 16233316
    nici
    Help: 266
    Rate: 983
    Even if I find it, I will not send it by e-mail
  • #10 16233319
    ren.lag.01
    Rate: 15
    I know, it's about 13gb ...
    I found the hamster
The discussion revolves around the installation of ODIS software purchased from AliExpress, where the user encounters the error "ODS9007E" during the update process. The user details their installation steps, including the use of a specific license file and modifications to the OffboardDiagLauncher.exe. Suggestions from other users include checking the postsetup database and ensuring Java is installed. The user also seeks assistance in locating a postsetup base, indicating that they are exploring torrent options for this file. The conversation highlights troubleshooting steps and community support for resolving installation issues.
