Affordable Walkie-Talkie Listening Scanner Recommendations: Comparing Models & Brands
konradj99 7983 6
  • #1 16246211
    konradj99
    I am thinking of buying a listening scanner, but the only contact I had was with them when I was trying to eavesdrop on our services. now I'm completely off topic. I am looking for a fairly cheap mobile device (walkie-talkie) I do not need to hear bandwidth for planes. I don't plan on installing a separate antenna for now.
  • #2 16246450
  • #3 16246604
    konradj99
    thank you for the great suggestions, but I bought UV-5R maybe too hastily, we'll see how it will work, although I don't expect miracles
  • #4 16249975
  • #5 16250011
    konradj99
    today I hope it will be delivered, I will see. Someone may have had contact with programming by computer? is a usb cable useful for this device?
  • #6 16250400
    Jap
    Help: 114
    Rate: 654
    For future I recommend TYT TH UV3R as a SCANNER for cheap quinolines.
    The UV-5R lacks such useful things as:
    1. Naming memory locations from the radio
    2. Inability to add and mask memory cells from the scanned list (in scanners it is the SKIP function).
    Interesting facts - TYT TH UV3R, after unlocking the computer, acts as a 3 flag - you can listen to e.g. shattered USARMA satellites at 255.550 MHz and has a much better housing (material).
    https://www.youtube.com/watch?v=nVvE53iX-i0
  • #7 16250470
    tomekm33
    Help: 42
    Rate: 120
    Let's start with the fact that the UV-5R is not a scanner, but rather a portable radio. This is not the receiver itself. I don't know how much you gave him. When it comes to listening scanners themselves, UNIDEN generally has a nice offer, e.g. UBC75XLT. It costs a few pennies, but if you want something more expensive it's worth it. And remember that the receiver is one thing. Your location is important, or rather the location of your antenna. And the antenna itself. River theme.
    On the other hand, if you bought a transceiver then maybe you might be interested in amateur radio? Maybe you have an amateur club nearby? You already have the first radio station :) Now get ready, get a license and you can broadcast something :)
✨ The discussion revolves around recommendations for affordable listening scanners and walkie-talkies. The user initially sought a budget-friendly mobile device without the need for advanced features like aircraft bandwidth reception or external antennas. Responses highlighted the UV-5R model, which the user purchased, but noted it is primarily a portable radio rather than a true scanner. Suggestions included the TYT TH UV3R for its scanning capabilities and features like memory management. The UNIDEN UBC75XLT was also recommended as a cost-effective listening scanner. The importance of antenna location and quality was emphasized for effective reception.
