Passat B6 Estate - Tailgate: Hatch Not Opening, Contact Issue & Emergency Lid Opening
bobo 44 8541 4
  • #1 16653892
    bobo 44
    Help: 28
    Rate: 196
    Hello, the hatch does not want to open, probably the contact does not work or someone knows how to emergency open the luggage compartment lid to get to this contact
  • #2 16653900
    andrzej20001
    Help: 1578
    Rate: 6669
    Open the triangle holder and use the hook in the clevis.
  • #3 16653960
    bobo 44
    Help: 28
    Rate: 196
    and electrically can't control some relay
  • #4 16653979
    andrzej20001
    Help: 1578
    Rate: 6669
    vag> bordnetz> element test if the lock is ok
  • #5 16654230
    bobo 44
    Help: 28
    Rate: 196
    Is there a fuse for the flap somewhere? If so, which one?
    Added after 4 [hours] 33 [minutes]:
    Hello, I got inside the flap opened only how to disassemble the black plastic from the flap to get to the switch I unscrewed 2 screws under the triangle flap and 2 on the back of the plastic front and what's next
    Added after 59 [minutes]:
    I managed to close the topic
