Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message ..
dawidqq 40791 6
  • #1 16264626
    dawidqq
    Rate: 11
    Hello, I get this message every time I start my computer:
    >> Checking Media Presence ......
    >> Media Present ......
    >> Start PXE over IPv4.
    It will turn itself off after about a minute, or just press the esc key. Maybe it's fine to hit the esc key, but I'm not the only one using it.
    Computer parameters:
    -Intel Core i5 6400
    -XFX Radeon RX 470 RS
    -MSI H110M PRO-VD PLUS
    -DDR 4 / 8gb RAM, probably from Good Ram
    -HDD 1000 GB
    -Intel 120GB 2.5 '' SATA SSD Series 535 7mm
    I think it is worth writing that the computer is new, but after one day of use, he visited the website where the motherboard was replaced. Same model but new. Before the service, I managed to install the Windows 7 SSD, card and board drivers, etc. When returning it to the service, I had to remove the ssd from it, because it was purchased separately. Then the computer turned on normally, i.e. without this message.
    I watched videos with the solution to this problem and changed some settings in Bios from uefi to csm. I can't find it at home, and due to the fact that I'm completely green in the subject, I am asking for help from someone who knows, because I don't want to spoil something myself.
    In the attachment I will add photos from Bios.
    Thank you very much in advance for your help
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115353.jpg (3.79 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115342.jpg (3.9 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115315.jpg (3.59 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115326.jpg (3.71 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115259.jpg (3.89 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115247.jpg (3.92 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115216.jpg (5.29 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115236.jpg (3.86 MB) You must be logged in to download this attachment.
    • Intel Core i5 6400k / XFX Radeon - Checking Media Presence popup message .. P70209-115052.jpg (2.29 MB) You must be logged in to download this attachment.
  • #4 16264828
    Kolobos
    IT specialist
    Help: 17165
    Rate: 10442
    Should I write it to you again?
  • #5 16264866
    dawidqq
    Rate: 11
    As I wrote above ^^ I am green, completely green and I don't want to spoil anything. Just exactly which option, i.e. whether this #boot optio 6 and 13.
    Kolobos
    IT specialist
    Help: 17165
    Rate: 10442
    You will not break anything, even if you change something badly, you can always set it later as it was before.
    Enter UEFI Network Drive and check if you can disable network booting there or at least set it to the last positions.
  • #7 16264933
    dawidqq
    Rate: 11
    Thanks a lot, I did as you wrote above. In UEFI Network Drive I gave disabled :)
✨ The user is experiencing a "Checking Media Presence" error message upon starting their computer, which is equipped with an Intel Core i5 6400 processor, XFX Radeon RX 470 RS graphics card, MSI H110M PRO-VD PLUS motherboard, 8GB DDR4 RAM, a 1TB HDD, and a 120GB Intel SATA SSD. This issue arose after the motherboard was replaced, and the user had to remove the SSD prior to service. Solutions discussed include disabling UEFI network booting in the BIOS settings to resolve the error. The user successfully disabled the UEFI Network Drive option as suggested.
