VW T5 1.9 BRS - Vacuum Diagram: N75 Upper Connector, Servo Hose & Blinded Tee Connection
darko b 25536 5
  • #1 16266292
    darko b
    Rate: 103
    Hello. A hose is connected to the upper connector of the N75 and the other end to the servo. On this hose there is also a tee with a hose that someone has blinded. Where should it be connected ???
  • #2 16266340
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Vacc is underpressure, out is output.
  • #3 16266938
    darko b
    Rate: 103
    The rigid vaccum tube is already connected to this hose at the servo itself, I am still waiting for hints :) I will add that the middle N75 connector is connected to the turbo pear and the lower connector is a small filter.
  • #4 16268231
    darko b
    Rate: 103
    Should there be a vacuum reservoir in this model?
  • #5 16268297
    marfur30
    Help: 138
    Rate: 386
    It should look like this
  • #6 16268502
    darko b
    Rate: 103
    This diagram is not for this car. This engine is only N75, but I looked at the engine from each side again and finally found it. This hose is connected to the valve cover from the front of the engine. I just wonder why someone blinded this hose ...?
