Connecting Terrestrial TV Programs with UPC's HORIZON Decoder: A Step-by-Step Guide
holmen 4608 8
  • #1 16267750
    holmen
    until recently I had a signal from UPC led to the "box" at home. there was an output for a telephone and analog TV decoder.
    They changed my / my request / the decoder to HORIZON and ......... I have one cable for the decoder and everything
    I would like to connect TV with terrestrial programs as before / broadcasts UPC as analog / Only how to do it ????
  • #2 16267927
  • #3 16271600
    szczodros
    Level 19  
    Help: 5
    Rate: 70
    I suspect that this "box" had filters and silencers inside. See directly on the cable if you have an analog signal with the device for which you need the signal.
  • #4 16271618
  • #5 16272045
    szczodros
    Level 19  
    Help: 5
    Rate: 70
    If without a power supply, this box is most likely just filters. Anyway, I would check if there is an analog signal in the bare cable itself.
  • #6 16277914
    Piotr3
    It would seem that the matter is simple - just install the Splitter 1/2 (4db) However, the parameters of the modem in the Horizon decoder will change (UPC no longer uses TRIS type splitters with a return path filter for the analog output) It is best to order additional installations from the operator sockets, cost PLN 50. The technician will install the appropriate components - crimp connectors, cable, splitter. We have guarantees for the service and we are sure that any subsequent service will not be paid.
  • #7 16278820
  • #8 16278921
    Piotr3
    Of course, TRIS splitters have a return path filter (for analog output) and do not ingress, such have been used in UPC for a long time, as well as separate K / Z attenuators. However, they have not been installed recently, now 1/2 and 1/3 splitters with an appropriate plastic cover are provided and such splitters are mounted on installations and modernizations of installations in the customer's apartment. What was the reason why UPC stopped assembling Tris - I don't know.
  • #9 16278934
The discussion revolves around connecting terrestrial TV programs to UPC's HORIZON decoder after a recent upgrade from an older analog setup. Users suggest checking the existing cable for an analog signal and recommend using a multimedia crossover instead of a splitter to avoid interference with the provider's network. It is advised to contact UPC for professional installation, as they can provide the necessary components and ensure proper assembly, which includes crimp connectors, cables, and splitters. The conversation highlights the transition from TRIS type splitters to newer models and the implications of this change on signal quality and installation practices.
