Netia Fiber Optic Upgrade: Improving Speed & Stability with TechnicolorTG389ac or New Router?
rgomez 9282 2
  • #1 16287085
    rgomez
    Hello. I have just changed my old internet in Netia to fiber optic up to 300 Mb / s in the same company. The Internet is connected with the old twisted pair (which is the cable from the beginning, clasa 5s), and the TechnicolorTG389ac router. At the beginning there was a problem with speed, the technician decided that the cable is broken or there is no one wire and the speed will be at most 100 Mb / s. Cable for exchange. I was not at home, my son was present. After arriving I checked the speed on the cable and in popular tests, on the PS4 and TV samsung comes out over 200 (on the computer within 300 Mb / s) that is probably ok. However, after WiFi is poor in the 30-Mb / s range and jumps down hard. The question is whether to replace it, whether to manage it from the supplier, or to buy a better router that will raise my speed and stability / stronger signal? and if so, which one?
  • #2 16287191
    fang13
    Contact them yet. I used to exchange a router with them three times before they gave one that was supposed to work: /
  • Diagnosing Wi-Fi limits with adapter and spectrum checks
    #3 16288381
    KOCUREK1970
    Help: 3860
    Rate: 5488
    rgomez wrote:
    However, there is a poverty of 30 Mb / s after WiFi
    But wifi no one guarantees - there is nothing to call the operator.
    And already 200 Mb after wifi - this network cards in AC computers must be and 5 GHz band (which in Polish housing conditions, is worse than 2.4 GHz).
    What kind of network cards do you have in computers?
    How is the ether aisolated? (install InSSIDera v2 / Home and insert the scan result here).
