Seagate Expansion 1TB Not Detected After Falling - Quick Signals Emitted
lydrayn 4995 11
Why is my Seagate Expansion 1TB external drive not detected after a small fall and emitting rapid clicking signals, and can it still be recovered?
The drive is likely not fixable at home; if the data matters, the only realistic option is a specialized data-recovery company [#16288613][#16288615] A normal service is not enough, and the quoted diagnosis/recovery costs were about PLN 600-1000 for diagnosis and PLN 2000-4000 or more for recovery [#16288613] If the data is not worth that much, the advice was to buy a new disk and forget this one [#16288613][#16288615][#16288639]
  • #1 16288510
    lydrayn
    Hi to all.
    There is a problem with my Seagate Expansion 1TB external drive.
    The disk fell from a height of 10cm, so really small. Since then, the computer can not see it, and when turned on for 10 seconds, it issued short but very fast signals.
    First, I checked the disk on 4 different devices, the same everywhere.
    I decided to unscrew it, hoping that it was just a loose screw.
    I attach a video of how it looks now.
    xfiles.linuxpl.info/dysk.mp4
    Anyone have an idea what might be wrong?
    • dysk.mp4 (18.67 MB) You must be logged in to download this attachment.
  • #2 16288528
    kokapetyl
    Help: 1787
    Rate: 2102
    lydrayn wrote:
    I decided to spin it
    To what extent ?
    Post links correctly, do not link to where the porn sites are. :D
  • #3 16288531
    lydrayn
    Relax, this is my working domain. Also, X Files, not XXX :)
  • #4 16288532
    Kasek21
    Help: 4981
    Rate: 3547
    First, remove the disk from the housing and check.
    Post a video as an attachment to the forum.
  • #5 16288550
    lydrayn
    Ok, I have already posted it as an attachment.
  • #6 16288552
    kokapetyl
    Help: 1787
    Rate: 2102
    Kasek21 wrote:
    First, remove the disk from the chassis
    The author probably did it emphatically. :D
  • #7 16288578
    Kasek21
    Help: 4981
    Rate: 3547
    There was no video available :)
    To the author: Nothing now! :lol:
  • #8 16288598
    lydrayn
    So nothing can be done anymore? Even if I take it to the site? Generally, from what I see, there is a rolled up foil under this "needle"
  • #9 16288613
    Kasek21
    Help: 4981
    Rate: 3547
    The diagnosis is probably PLN 600-1000 - recovery is not known but you can probably aim at PLN 2000-4000 - unless more.
    PS. ... and not a service but a specialized recovery company!
    Bottom line: if you don't care about the data or are not very important (worth) then buy a new disk and forget about it!
  • #10 16288615
    kokapetyl
    Help: 1787
    Rate: 2102
    Let go of this disk, unless you have data worth a few thousand zlotys there.
  • #11 16288624
    lydrayn
    The disk cost about PLN 350, so I don't care about the disk, but when it comes to data - I had everything there.
  • #12 16288639
    Kasek21
    Help: 4981
    Rate: 3547
    Written more than once - a copy !!!
    If so important it will cost!
The discussion revolves around a Seagate Expansion 1TB external drive that became undetectable after a minor fall. The user reports that the drive emits rapid short signals when powered on and is not recognized by multiple devices. Suggestions include removing the drive from its housing for inspection and considering data recovery services if the data is valuable. Responses indicate that recovery costs could be significant, and if the data is not critical, purchasing a new drive may be advisable. The user expresses concern over the lost data, which was deemed important.
